Old 06-10-2014, 04:46 AM   #1
Odd Starting Problem
2001 Base Boxster. This problem has just recently popped up. In the morning I will go out to start the car and when I turn the key the engine will turn over and attempt to start, but will not fully start up and when I release the key the engine dies. This will happen 6-8 times and then the engine will completely start. After that it starts and runs fine for a few days and then it happens again. Not sure where to start with trouble shooting this problem. Any suggestions? Thanks!
2003 Boxster S
1991 BMW 318is
'93 Ducati 900SS
'76 BMW R75/6
'73 Honda Scrambler
Kurt V is offline   Reply With Quote
Old 06-11-2014, 04:41 AM   #2
Anyone? Problem has now occurred two mornings in a row. I'm wondering if this might be a result of some check valve failure that allows the gas to drain out of the injector lines over night?
2003 Boxster S
1991 BMW 318is
'93 Ducati 900SS
'76 BMW R75/6
'73 Honda Scrambler
Old 06-11-2014, 07:00 AM   #3
Multi-Boxer Driver
Deserion's Avatar
Have you checked the pressure at the port on the fuel rail after it's been sitting?
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 06-12-2014, 05:38 AM   #4
No I have not. I have the shop manual, so I will try and do that this weekend.
2003 Boxster S
1991 BMW 318is
'93 Ducati 900SS
'76 BMW R75/6
'73 Honda Scrambler
Old 06-12-2014, 04:31 PM   #5
rp17's Avatar
Battery is ok? Just did the swap on mine but it wouldn't start at all but tried if you know what I mean.
Old 07-02-2014, 10:05 AM   #6
Just wanted to do a follow up. More research indicated possible dirty MAF sensor leading to the problem. So last Saturday I replaced the MAF sensor. Old sensor was quite filthy. Also removed and cleaned the throttle body. The intake was coated in a dirt/oil film. Possibly from the after market K&N air filter. Replaced with OEM filter. Also replaced the spark plugs and spark plug tubes. Car is running great!
2003 Boxster S
1991 BMW 318is
'93 Ducati 900SS
'76 BMW R75/6
'73 Honda Scrambler
Old 07-02-2014, 11:31 AM   #7
+1 and kudos on the follow up so the next person can find what actually solved the problem!
Nothing worse than reading through pages of problem discussion only to find that the OP never posted the solution.
Old 07-02-2014, 01:53 PM   #8
Jinx's Avatar
I second that.
Jinx
Jinx & Bill
Jinx is offline   Reply With Quote
