05-21-2014, 08:50 AM
#1
No high frequency audio from door speakers
I have a problem with my stock audio system, I have no high frequency sound coming from the front door speakers, only lows. If I fade or balance to either of the door speakers, audio is almost non-existent.
Does anyone know if the door speakers use separate signal feeds for highs and lows from either the head unit or the amp?
05-21-2014, 09:14 AM
#2
"Cool Prius!" - Nobody
05-21-2014, 09:33 AM
#3
Originally Posted by Burg Boxster
Well this is a bizarre "feature"... So all I really need to do is replace the 5.25 door "sub-woofers" with some full range?
Oh, and thanks for the info.
05-22-2014, 08:45 AM
#4
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
05-22-2014, 09:00 AM
#5
Wait, i'm confused. The door has a "woofer" in it, the dash has a mid and tweet. you should NOT get highs from the door. replacing the speakers with ones that have a tweeter is *probably* not the right answer. if you are not getting any high-frequency response, it's the dash speakers that are likely your issue...
Mantis 2.0L Deep Sump, de-snorkeled, Bilstein PSS9 Coil-Overs, Rennline lug studs, and auto crossed regularly.
05-22-2014, 10:00 AM
#6
No, the dash speakers work fine, (if you can call it that...), highs and mids are there. As I have been graciously humbled to learn that the door speakers are nothing more than "subs" that are clipped at around 70hz by the stock amp, even replacing them with a decent set of coaxial speakers will do no good unless I also change out the amp, which would also dictate a new HU as well...
I forgot who said it, but the money is better spent on a new exhaust and enjoy that music.
05-22-2014, 10:18 AM
#7
Correct - it is a slippery slope...all about priorities!
