Old 05-01-2014, 04:05 PM   #1
Flywheel Bolt Torx/Star size?
Anyone know off the top of their head what size Torx/star socket is required to remove the 986 2.7 flywheel bolts? I have a T50 but its too small, trips to the parts store to buy tools is not my favorite past-time.
mgfranz is offline   Reply With Quote
Old 05-01-2014, 05:54 PM   #2
Registered Boxster abuser
healthservices's Avatar
Pretty sure its a 55. Go to Harbor freight and get their cheap set. the quality on those are decent
Old 05-01-2014, 07:19 PM   #3
Yes it's a 55, I used yesterday and luckily I found it inside my toolbox.. :-)
Old 05-01-2014, 05:55 PM   #4
or you can borrow from me but Ill be needing it back soon. I'm in n. tustin
Old 05-02-2014, 07:19 AM   #5
DennisAN's Avatar
Sears has been discounting the Lisle set of Torx bits down to $20 lately. They are made in the US.
Base 2000 986, beater 1996 Miata, 2011 Suzuki SX4 AWD
Feline mechanics Condoleezza and Dukie
DennisAN is offline   Reply With Quote
Old 05-02-2014, 12:15 PM   #6
I originally bought these things from Harbor Freight thinking that they'd be good for just one or two uses, surprisingly they have lasted several jobs and well over a year. No breakage yet... Knock on wood. The 55 shown in the picture has been neck down so that it could be used for a BMW m5 dual mass flywheel. I've used my heavy duty impact with no issues.
Sent from my SAMSUNG-SGH-I317 using Tapatalk
Old 05-02-2014, 02:57 PM   #7
DennisAN's Avatar
Sadly my local HF only stocks the non-impact Torx set. Adding in shipping the Lisle impact set was cheaper.
Old 05-04-2014, 11:04 AM   #8
Yeah, it's a 55. Harbor Freight had the entire 1/2" drive set on sale for $12.99 on Friday, NAPA wanted $8 for just one. Impact to remove worked excellent! Even if I get only 2-3 uses out of it it is definitely worth it.
Thanks all!
Old 05-10-2014, 10:02 AM   #9
I am about to do this job today so I'll confirm later on but meanwhile...
Did you try T55 ? The T55 is included in some of the inexpensive kits from Harbor Freight. The bolts will be tight so get the 'impact' best quality they sell. And you'll need to make a tool to hold the flywheel in place.
If you are hunting for the tool online ,they are often called XZN or 12pt. spline.
I hope this helps you.
Old 05-10-2014, 10:50 AM   #10
DennisAN's Avatar
NO.
A Torx bit is a 6 pointed star.
A XZN or triple-square bit is a 12 pointed spline.
BOTH are used all over Boxsters.
