Old 04-13-2014, 02:03 PM   #1
Blown engine
I have a low mileage (34k) 1998 Boxster that suddenly died while driving. It was running perfectly prior to failure. No telltale noises or smoke. Couldn't restart so I put it back into my garage. Looked the next day and noticed a puddle of antifreeze (about a quart) under right side near exhaust. Closer examination revealed antifreeze coming through clamp connecting exhaust pipe to muffler indicating antifreeze got into exhaust. What's going on? How do I narrow down the problem? HELP! PLEASE!
Calijim is offline   Reply With Quote
Old 04-13-2014, 02:19 PM   #2
I am my own mechanic....
Timco's Avatar
Cracked head. Antifreeze escaping and being in exhaust.
Hope it's something easier. Keep us updated.
'08 VW Touareg T-3 wife's car
Old 04-13-2014, 04:35 PM   #3
Blown engine
Researching "cracked head" I came across a product called Heal-a-Seal: http://www.heal-a-seal.com/WARPED-CRACKED-ENGINE-HEADS-CYLINDER-BLOCK-CRACKS-REPAIR.html]HEAL-A-SEAL BLOWN HEAD GASKET, WARPED/CRACKED ENGINE HEAD, CYLINDER LEAK REPAIR KIT
Could this actually work?
Old 04-13-2014, 05:00 PM   #4
Has anyone had any success with sealant kits for cracked head/blown gasket repair? If not a good alternative, what would it cost to replace a head gasket on a 986 Boxster engine?
Old 04-13-2014, 05:07 PM   #5
BIGJake111's Avatar
It was done on mine for 4k i believe under the PO by an independent. I can dig out papers if youd like.
Old 04-13-2014, 05:44 PM   #6
Is there coolant in the oil or oil in the coolant?
runjmc2 is offline   Reply With Quote
Old 04-13-2014, 05:46 PM   #7
Timco's Avatar
Sealants seal more than the leak. Don't go there. Get actual quotes for the real issue. Tow it to a trusted Indy. Then you at least know what's up.
Old 04-13-2014, 06:50 PM   #8
Beginner
Jamesp's Avatar
From what I've read on this forum, head gaskets don't blow, but heads do crack. You can get it welded and rebuilt, or get a rebuilt for about $1200. I've seen the rebuilts dissed as likely to have more problems but I have no data on that.
2003 S manual
Old 04-13-2014, 07:07 PM   #9
This exact case happened to my son in-law's car. Same exact symptom. Luckily he was driving through a parking garage. The car stalled, engine died and could not restart. Puddle of coolant under the car.
Luckily it was a minor issue. Water pump and belt failure.
2008 Boxster S PDE2
02 Boxster S Blk on Blk(Stock for the Wife)
88 turbo S (My Toy) slightly modified
cas951 is offline   Reply With Quote
Old 04-13-2014, 09:58 PM   #10
Engine Surgeon
Slipped sleeve.. The coolant is entering the exhaust through a cylinder that has an open exhaust valve and a cylinder failure.
These are sudden failures with the exact same failure scenario that you have outlined, they generally happen to low mileage engines that would have failed under warranty if they were driven enough.
This is mode of failure #1, its the first failure we ever documented...
US Patent 8,992,089 &
US Patent 9,416,697
Old 04-13-2014, 10:07 PM   #11
The Radium King's Avatar
make sure it is coming out out the exhaust and not from someplace above it. the coolant reservoir is on the right side and above where you are seeing coolant. the coolant might be coming from a cracked reservoir (common failure on these cars) or from a reservoir that boiled-over (there is a drain that dumps out in the right wheel well). it could be as simple as a bad water pump or serpentine belt and the car overheated.
Old 04-14-2014, 12:56 PM   #12
Beginner
Jamesp's Avatar
Let us know how this turns out. We could be on Car Talk playing stump the chump.
2003 S manual
Old 04-15-2014, 05:59 PM   #13
I don't know why folks don't listen to Jake...he's seen more failures than any of us in our lifetimes.
Sounds like engine is toast...
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
Old 04-15-2014, 06:22 PM   #14
Timco's Avatar
Because catastrophic failure is not the only possible cause of coolant on the floor? Hoping for the best.
Old 04-15-2014, 06:53 PM   #15
Beginner
Jamesp's Avatar
Jake does have more experience than most of us put together but that does not mean there can not be another explanation. All of the possibilities seem like reasonable possibilities. Checking for a broken coolant reservoir before removing a head sure makes sense to me. Having said that, if I were a betting man I'd be betting on Jake.
2003 S manual
Old 04-15-2014, 10:46 PM   #16
Like runjmc said, check if there is oil in the coolant or coolant in the oil. If there is oil in the coolant, don't panic, it could be a failed oil cooler which is any easy fix, except for cleaning out the cooling system. If there is coolant in the oil, that's not good.
Take off the serpentine belt and crank the motor by hand. If it binds, then you have a major problem. If not, take out the spark plugs and see if coolant is in he cylinders, if so you have a major problem.
If you don't have any of the above problems, then it could just be the car overheated and barfedcoolant. Fill up he coolant reservoir and see I it starts. If so, check the cooling system for faults. Hopefully it's just a waterpumpmor a cracked coolant reservoir.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 04-16-2014, 09:12 AM   #17
Engine Surgeon
I'll put a 100 dollar bill on it.
Anyone want to dance?
I have been wrong before :-)
But it could always be worse.
US Patent 9,416,697
Old 04-16-2014, 11:21 AM   #18
Rob175's Avatar
For the first time my RED coolant warning light started blinking (98' Boxster w/72,00 miles) when I started up..... lucky for me it the coolant was low by about 1-1/2 cups...I suppose just enough to trigger the low coolant sensor. I'll assume evaporation over the years was the cause. I bought the newer version coolant cap thinking the old cap might also be the culprit. Sorry to read some have much more serious issues.
Rob175 is online now   Reply With Quote
Old 04-16-2014, 02:38 PM   #19
Beginner
Jamesp's Avatar
I think the wrist pin "C" clip might be loose on that piston.
2003 S manual
Old 04-16-2014, 02:42 PM   #20
Damn Yankee
TeamOxford's Avatar
Those rings need to be reseated also. I'll bet the compression is WAY off on those cylinders.
Just sayin'...........
TO
Tags
exhaust leaking coolant
