Like runjmc said, check if there is oil in the coolant or coolant in the oil. If there is oil in the coolant, don't panic, it could be a failed oil cooler which is any easy fix, except for cleaning out the cooling system. If there is coolant in the oil, that's not good.
Take off the serpentine belt and crank the motor by hand. If it binds, then you have a major problem. If not, take out the spark plugs and see if coolant is in he cylinders, if so you have a major problem.
If you don't have any of the above problems, then it could just be the car overheated and barfedcoolant. Fill up he coolant reservoir and see I it starts. If so, check the cooling system for faults. Hopefully it's just a waterpumpmor a cracked coolant reservoir.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
