Thread: Blown engine
Old 04-13-2014, 09:07 PM   #11
The Radium King
The Radium King's Avatar
make sure it is coming out out the exhaust and not from someplace above it. the coolant reservoir is on the right side and above where you are seeing coolant. the coolant might be coming from a cracked reservoir (common failure on these cars) or from a reservoir that boiled-over (there is a drain that dumps out in the right wheel well). it could be as simple as a bad water pump or serpentine belt and the car overheated.
