Old 04-10-2014, 06:37 AM   #1
Question H6W Bulb Replacement
What do you guys use for H6W bulb (parking light) right below the HID/Xenon/Litronic bulb? A lot of the LED options seem to be oversized so they most likely won't fit through the tube.
Just paid $19 for one at the dealer, that's $1.80 saved with PCA discount! :ah:
Old 04-10-2014, 03:18 PM   #2
lkchris's Avatar
I installed Phillips Blue Vision
H6W Philips Blue Vision Sidelights (pair)
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
Old 04-12-2014, 12:35 AM   #3
Boxster S '53'
Ive just installed these on mine
Side Light High Power Bulb. SMD LED H6W - 99963114090LED, Porsche | Design 911
They fitted fine & give the light a much better look complementing the litornics
from this:
to this:
& yes still have the amber to remove from the headlight!
Blankman is offline   Reply With Quote
Old 04-17-2014, 05:38 PM   #4
winter.k's Avatar
Blinkman - that looks good, big difference.
How does it look in the dark, is it more bluish than the litronic bulb? Im looking for a very crisp white bulb.
winter.k is offline   Reply With Quote
Old 04-18-2014, 06:44 AM   #5
Blankman:
They look good, but these bulbs are $25 and they want $25 for shipping to Canada... !
Old 04-18-2014, 07:22 AM   #6
Originally Posted by ekam View Post
Blankman:
Not worst than PelicanParts !
39$ to ship tiny dashboard bulbs to Canada...
2003 Boxster S
The French Dude is offline   Reply With Quote
Old 04-18-2014, 07:37 AM   #7
I just went through this a few months ago and couldn't believe how hard it was to source a local bulb!
I ended up with a bulb from NAPA...$10! Highway robbery for a parking bulb but a real bargain for a H6W!
Old 11-05-2015, 10:59 AM   #8
Finnegan's Avatar
My passenger side lower headlight bulb went out yesterday, and I'd like to replace them both with these. Does anyone know the part number, and a source in the US?
from this:
to this:
Old 11-05-2015, 03:09 PM   #9
07 Carrera S Cab
Boxtaboy's Avatar
Is there any other purpose for those parking lamps besides being a parking lamp which I never use? First one side went out on mine, so I just left it, and a month or so later, the other side went out, so I just left it as well. Lol. Looks fine, and I don't need no stinkin parking lights.
Old 11-05-2015, 03:38 PM   #10
Unless NJ is extremely lenient, you will need them at inspection time.
Old 11-05-2015, 03:41 PM   #11
07 Carrera S Cab
Boxtaboy's Avatar
They never check whether the lights work on the car. In fact, I just passed mine a few months ago when one side was out. Lol
Old 11-05-2015, 03:43 PM   #12
Lucky you
I've been denied inspection stickers for them being out. Inspectors check every single exterior light here.
Old 11-05-2015, 04:12 PM   #13
Finnegan's Avatar
I like to use the parking lights in the daytime. Does anyone know of a US source for these? My indy shop doesn't know where to find them.
This is the part code from the site in the UK. I don't know if that corresponds to a part number.
SIDE LIGHT HIGH POWER BULB. SMD LED H6W
Code: 99963114090LED
Old 11-05-2015, 05:55 PM   #14
Pdwight's Avatar
2pcs No Error White 8 SMD BAX9S 64132 H6W LED Parking Position Light Bulbs 96 | eBay
Old 11-05-2015, 09:11 PM   #15
Keep in mind that the H6W is for Litronics only. If you have halogens, they use a different bulb type for the parking lamp.
Old 11-06-2015, 08:14 AM   #16
lkchris's Avatar
Well, there's the thing where you're (temporarily) driving with a burned out headlight bulb. Nice to have some light on that side so others can tell you're a car and not a motorcycle.
Porsche thinks they're so important as to provide multiple ways to turn them on--both, left only, right only.
Kent Christensen
Albuquerque
2001 Boxster
2 BMW motorcycles
Old 11-06-2015, 10:36 AM   #17
Finnegan's Avatar
Now I'm not sure if mine are Litronic or Xenon.. I thought the option available in 2004 was Bi-Xenon? Here's a shot of my (smashed in parking lot) headlight:
Old 11-06-2015, 12:06 PM   #18
"Xenon" is a type of bulb. Litronics use xenon bulbs for the low beams. Standard 986 headlights use halogen bulbs for both the low and high beams. Porsche never made a bi-xenon headlight for the 986, only xenon or halogen.
Lits only have xenon low beams and use halogen for the high beams, so technically Litronics are a xenon/halogen hybrid.
You have Litronics.
Old 11-06-2015, 12:23 PM   #19
Finnegan's Avatar
Thank you!
Old 11-06-2015, 05:44 PM   #20
lkchris's Avatar
Actually, "bizenon" is more a marketing concept and the litronics could easily fit the definition.
HID burners are not good for high beams because of their delay in coming to full brightness. Mercedes, for one example, used the bizenon term to describe a process where a moveable metal shield adjusted between high and low positions to provide both beams from the same bulb/burner.
In litronic, a halogen bulb comes on to provide a quick high beam but also the level of the low beam hid projector is mechanically adjusted higher to supplement. It's obviously not as instantaneous as the halogen bulb. Pretty much the same result as bizenon.
Kent Christensen
Albuquerque
2001 Boxster
2 BMW motorcycles
