Old 04-14-2014, 01:28 PM   #61
Perfectlap's Avatar
The Spin On filter adaptor omits the factory bypass that diverts bypass oil around the filter at start up and at times of higher than normal oil pressure. During these periods the factory filter does not filter 100% of the oil. Tis is also even more true if the factory bypass spring has lost tension due to high oil temps or time in service.
Does this mean that using a factory filter will have a marginal increase in engine wear over the WIX type?
p.s.
Would the IMS Guardian be of value in this situation? One where you already have debris in they system however fine.
BORN: March 2000 - FINLAND
Old 04-14-2014, 01:29 PM   #62
Beginner
Jamesp's Avatar
Benjamin, I think its a very high probability you nailed it with the thought that the metal flakes were from the previous failure because of where you found them. That's pretty darned insightful. From my limited experience of rebuilding one m96 after an IMSB failure, the path you've laid out makes excellent sense particularly as you are going in eyes wide open to the possible risks and benefits. Keep us posted!
2003 S manual
Old 04-14-2014, 07:25 PM   #63
thom4782's Avatar
I've heard that one should flush the oil system multiple times until there are no more metal pieces. A spin on filter with a magnet and a magnetic drain plug will help.
Even then, I'm wondering whether one should use an unsealed bearing at all. I'm not sure a sealed bearing is an option these days, but if the seals last 50,000 miles then at least the IMSB won't fail due to any shavings left in the lubrication system.
What do other people think?
