Old 03-29-2014, 06:41 PM   #1
Jager's Avatar
Oh No The Jägermobile Broke Today!
The Jägermobile broke on the way to lunch today… Guess what happened?
Jäger
300K Mile Club
Old 03-29-2014, 06:47 PM   #2
Washer fluid leak?
Old 03-29-2014, 06:49 PM   #3
Jager's Avatar
Washer fluid leak?
Nope, it's full of washer fluid.
Jäger
300K Mile Club
Old 03-29-2014, 06:59 PM   #4
BIGJake111's Avatar
Fuel or Water pump?
Old 03-29-2014, 07:01 PM   #5
Jager's Avatar
Fuel or Water pump?
Nope... But good guess.
Jäger
300K Mile Club
Old 03-29-2014, 07:02 PM   #6
BIGJake111's Avatar
Headlight fluid then :troll:
Old 03-29-2014, 07:06 PM   #7
Broken half shaft?
Old 03-29-2014, 07:08 PM   #8
Jager's Avatar
Nope... Not a good guess.
Hint: There was a pool of oil under the motor on the Drivers side when off-loaded from the tow truck.
Jäger
300K Mile Club
Old 03-29-2014, 07:14 PM   #9
Rock hit your oil filter housing
Polaris is offline   Reply With Quote
Old 03-29-2014, 07:16 PM   #10
Jager's Avatar
Negative... What kind of roads do you drive on??
Jäger
300K Mile Club
Old 03-29-2014, 07:18 PM   #11
BIGJake111's Avatar
Aos but wouldnt this be your like 18th aos haha.
Old 03-29-2014, 07:21 PM   #12
Jager's Avatar
You are correct... AOS... It will be my third AOS. I already removed it and ordered another one. I will probably install next weekend. Why can't Porsche improve this part??
Jäger
300K Mile Club
Old 03-29-2014, 07:23 PM   #13
Is the flatbed voluntary or mandatory?
nicecar is offline   Reply With Quote
Old 03-29-2014, 07:40 PM   #14
BIGJake111's Avatar
Wouldve been my first guess if it wasnt for you having replaces so many times before, i am assuming mine is on its original, and has 106k miles... time to look into some preventive m.
hope you have your box running in no time!
Old 03-29-2014, 07:45 PM   #15
Jager's Avatar
Now that I think of it... I replaced the AOS three times so this makes it number four for this Boxster.
Jäger
300K Mile Club
Old 03-29-2014, 07:46 PM   #16
Beginner
Jamesp's Avatar
What path did the oil take to end up under the left side of the engine?
2003 S manual
Old 03-29-2014, 07:49 PM   #17
Jager's Avatar
Through the induction system over to the Air Box below the air filter... There is a drain at the bottom of the Air Box.
Jäger
300K Mile Club
Old 03-30-2014, 05:54 AM   #18
kk2002s's Avatar
Ok Monday morning QB time
Are there indications you can think back on that may have been due to the AOS failing?
So when the AOS fails, does the car become un-driveable or in this case it was the oil leakage that scared you?
I was going to guess you lost one of your tire's valve stem caps
Seal Grey
Old 03-30-2014, 06:49 AM   #19
Dave S.'s Avatar
What in the world would cause your AOS to fail 4 times? Seems like maybe it's a symptom of a root cause problem that hasn't been addressed.
Dave S.
2003 Boxster S
Old 03-30-2014, 06:57 AM   #20
Engine Surgeon
Operating environment being near sea level doesn't help as atmospheric pressures are greatest there and pout more load on the AOS internals.
I find that extended oil service intervals lead to this more than anything as acids in the oil reach levels that create diaphragm degradation within the AOS.
US Patent 8,992,089 &
US Patent 9,416,697
