Old 03-11-2014, 01:33 PM   #1
Remove gas pedal - help needed
Trying to replace the carpet in a 99 base. Old carpet was cut at top to fit around pedal. New carpet is not, and though I could cut it, appears that should not be necessary. How do you loosen (remove) the gas pedal assembly from the floor board?
I found one screw at the top, next to the cable, which was long enough to go all the way to the floorboard, but the pedal assembly is still not loose.
Would appreciate your help. Thanks, Joe
Xcellr8 is offline   Reply With Quote
