Old 11-19-2015, 03:27 AM   #21
mikesz's Avatar
X1/9? WOW! I had a 78 always lots of maintenance but a blast to drive!
99 Porsche Boxster
Old 11-19-2015, 05:29 AM   #22
Giller's Avatar
Originally Posted by mikesz View Post
I was at a self serve gas station and some ahole barreled in and tapped my rear bumperettes. sad thing was he had no clue what he had done and there was no damage. but you know what? I still like the clean euro look without the bumperettes. Sick and tired of people trying to pass laws because the common USA citizen is to stupid to know what is going on around them. I took the bumperettes off and glad I did I like the look, its clean, if someone hits me I will fix/get a new bumper and put it back on. Not trying to start a riot on this forum but opinions are like ****************************s everybody has one and I don't care about yours!
You're not trying to start a riot...then why act like a ******* yourself? If you don't care about others opinions, that's fine. You don't have to be a ******* about it yourself. Just smile and nod and go about your day.
Old 07-18-2020, 11:55 PM   #23
here is what I did once I removed bumperettes.Thoughts?
How did you get that plastic to stick on the car? looks great. would really like to do that mod. thx
jjjohnnyq is offline   Reply With Quote
Old 07-19-2020, 04:37 AM   #24
1998 Boxster Silver/Red
I did the delete about a month ago. The plastic stays on by virtue of the license plate holder. Plastic part goes on... plate holder on top... the screws... it's secured.
my delete plate is 3mm thick, so I put some doubkle sided tape on the back... to help it adhere. Didn't work for me because of the slight curve of the bumper cover. I'm going to give it a second look today.
So... just a couple license plate bracket screws... you'll be set.
Edit: The plate in the pic from your post is the exact one I installed on mine. Thanks, again, Mikesz.
1998 Porsche Boxster
Old 07-22-2020, 11:30 PM   #25
Thanks for the info. Mine is going in next week and that back bumper has to come off for exhaust so I am going to get started. I am assuming those silver metal bumps that are hidden by the bumperettes just unscrew from the long metal " bumper " and leave the square area to be covered by the new back plate? Did you just cut out 3mm plastic to fit the opening? That might be a little above my pay grade , might have to have someone make it for me
Old 07-23-2020, 03:53 AM   #26
Those silver metal bumps... that are hidden behind the plastic bumperatte covers... are affixed with rivets. I was going to drill them out... then learned that they can be pounded out. I took a nail punch and hammer... positioned on top of each respective rivet... gave a swift pound... and they popped right off.
The 3mm plastic delete panel I purchased from a member who had made his own outline then outsourcing the cutting of the actual plastic delete panel to a glass shop. I imagine you'd have to have a steady hand to draw and cutout a template.
Old 07-23-2020, 09:53 AM   #27
jaykay's Avatar
986 00S
Old 07-23-2020, 10:00 AM   #28
jaykay's Avatar
I went euro bumper cover. Not cheap at all but it's done.
Consider going grilled and designing it such that it looks good. Black on back works to hide imperfections. You may have to repaint after cutting.....this is the main issue with this. You will have to get the beam behind the grill painted drilled out to make it look good and get cooling happening. Cutting down heat shield for air flow out is another task along with plate mounting
986 00S
Old 07-23-2020, 04:49 PM   #29
The Euro bumper is the same as the US bumper with the exception of the cut outs to accomodate the bumperettes. The upside to having the "Euro" version is that you don't need the delete plate.
Now... if you want to do some cutting... some mesh... some cooling...
Figure out how to run two exhaust pipes side-by-side the license plate.
