02-01-2014, 08:50 PM
Boxster S Bassist
IMSB: what else should be done at same time?
Took my 2000 S in for an oil change and found the dreaded metallic fragments in the oil filter, thankfully before the bearing self destructed. Will have the LN Engineering ceramic bearing installed. In addition to clutch replacement (car has 74K miles) what else should be done at same time? I assume throw out bearing, how about the throw out bearing guide tube? How about transmission mounts? Rear main seal? (Is this the same as the "transmission seal"?) Anything else? Thanks!
02-01-2014, 09:04 PM
Engine Surgeon
Our first level package includes IMSB, RMS and clutch kit.
That said, if you already have material laden oil, the IMS Retrofit procedure changes, else the replacement bearing, and the rest of the engine could become compromised at a later date.
See this link.
Bearing already failing?
US Patent 8,992,089 &
US Patent 9,416,697
02-02-2014, 01:54 PM
Originally Posted by That said, if you already have material laden oil, the IMS Retrofit procedure changes, else the replacement bearing, and the rest of the engine could become compromised at a later date.
See this link.
[url=http://imsretrofit.com/bearing-already-failing/
Bearing already failing?[/url]
Jake is making a good point here. I would look into what it takes to get all of the flakes out of the oil, and consider a sealed bearing from Pelican or a sealed ceramic.
02-02-2014, 02:45 PM
Engine Surgeon
The debris is harmful to much more than just the replacement IMSB, it will impact every internally lubricated component within the engine if operated long enough.
Remember, the stock oil filter bypass is horrible and at start up it bypasses oil around the filter and straight to the bearings (especially in cold temperatures), when it becomes clogged with debris even more oil is bypassing the filter. When carrying out an IMSR its wise to replace the filter housing, or add the LN Spin On Filter Adaptor, to fully filter all the oil without the chances of bypassed oil.
We find over half the filter housings that we see have weakened bypass springs, which allows more bypassed oil to be routed around the filter.
Its the little things that no one thinks about, because they haven't taken the time to develop the solutions themselves.
US Patent 9,416,697
02-02-2014, 06:50 PM
Beginner
Jake speaks the truth. Any filings are your enemy. I strapped rare earth magnets around the outside of my oil filter housing. If it's ferrous and in the filter, it not going anywhere but to the magnets. The PP bearing is not sealed. The rest of the kit is worth it. I chose a Nachi sealed bearing to supplement the PP kit for what that's worth. In any event, if you have ferrous metal in the engine you have to get it out.
2003 S manual
02-03-2014, 07:47 PM
Boxster S Bassist
A question for Jake. My car being an early 2000 S model might have a double or single row bearing. I intend to install the LN ceramic bearing. How do I know if I will get the single or dual row type? Even if I have the single row stock bearing I'd want the dual row ceramic type. Thanks!
02-01-2014, 09:23 PM
I am my own mechanic....
Check oil pan for pieces. The bearing condition when pulled (special procedure) will tell you what you lost or if the issue is chain guides related. IMS isn't the only possible source.
Particles in filter magnetic?
Reinstall magnetic oil plug.
'08 VW Touareg T-3 wife's car
02-02-2014, 11:57 AM
Boxster S Bassist
Good advice, thanks!
02-02-2014, 12:49 PM
Porsche "Purist"
The rear main seal and transmission input shaft seal are different parts. The rear main seal is best installed using the factory special tool.
[IMG]  [/IMG]
1987 924S. 2002 996TT. PST-2
