Old 11-23-2013, 01:16 PM   #1
Max spacer
Hi all, I was wondering what is the max spacer's size I can fir on a 2003 Box S 18" ?
Thank you
2003 Boxster S
The French Dude is offline   Reply With Quote
Old 11-23-2013, 01:32 PM   #2
jsceash's Avatar
I hate to say this but, that is a completely wheel/tire dependent question. I have Boxster S II 17" stock rims although they are not 18" I can not put spacers on the rears with 265 tires. The front will take up to a 21MM space with 225 tires. I track 18" OZ Alleggerita HLT. 9" rears again I can't run a spacer with 275 tires. The front 8.5" I can run a 14mm spacer with 235 tires.
It's going to depend on your combination
Off track I run 1 degree front and 1/2 degree rear chamber
On track I run 1.5 -2 degree front and 1 degree rear chamber
Old 11-23-2013, 01:57 PM   #3
Oh ok and I suppose I have no way to know what size buy before buying ?
2003 Boxster S
Old 11-23-2013, 02:09 PM   #4
ganseg's Avatar
He just means the offset of the wheel, the camber, and the width of the wheel and tire come into play. Even the same size of different tires will fit differently. If you have the set-up you want already, you could start by eyeballing how much further out the tires could be without hitting when going over a bump.
ganseg is offline   Reply With Quote
