Old 11-23-2013, 02:29 PM   #21
jcb986's Avatar
Put the Cayman wheels on today. Backs fit fine. Fronts are tight but do not rub, may still add some spacers. Now I will take them the tire shop and have them rebalanced and checked.
Old Hippie Young Heart
jcb986 is offline   Reply With Quote
Old 11-23-2013, 02:59 PM   #22
ganseg's Avatar
What size are the front tires?
ganseg is offline   Reply With Quote
Old 11-24-2013, 05:39 AM   #23
jcb986's Avatar
18x8 ET 57
235/40/18
Old 11-24-2013, 06:59 AM   #24
ganseg's Avatar
Exactly what I had except my tires were Hankook. The tires were used too, so some of the height was worn off, but they rubbed the strut perch on the inner 3/4" of the tread.
I wonder - I have seen some aftermarket where the strut perch is higher, I wonder if mine are non-oem and a little lower.
Old 11-24-2013, 09:32 AM   #25
jcb986's Avatar
What year is your ride. Mine is a 2000 S. I was thinking it had the M030 suspension. I wrote down the shock number and has the standard shocks. It maybe the tire aspect ratio or the sidewall is not supported enough. Mine has the Michelin Pilots. Of course the shock and springs may be different than mine.
Old 11-24-2013, 12:05 PM   #26
ganseg's Avatar
Mine is a 2002 with 123,000 miles. It is possible they were replaced. My tires were 235/40 also. We're the part numbers obvious with the wheel off? I didn't check that.
Old 11-24-2013, 12:12 PM   #27
jcb986's Avatar
Next time I will look better, the shock numbers were stamped on the shock, so that was pretty easy to check. My build codes do not show a suspension change. I was thinking, maybe the shock on that wheel has or is going bad. I had not quiet a 1/2" clearance from tire to strut bottom, both sides, a 1/4" from backside of tire to strut. Car was on the ground when I checked it.
Old 11-05-2014, 03:03 PM   #28
8x18 et 57 front with Brey Krause 7mm extended hub spacers
235/40/18 Michelin Super sports
18x9 et 43 rear 5mm spacers
265/40/18 Michelin Supersports
Life is like Racing, do not hit the brakes until you see God!
There is a fine line between hobby and mental illness.
www.qikqbnboxster.mysite.com
qikqbn is offline   Reply With Quote
