Old 11-24-2013, 11:12 AM   #27
jcb986
jcb986's Avatar
Originally Posted by ganseg View Post
Mine is a 2002 with 123,000 miles. It is possible they were replaced. My tires were 235/40 also. We're the part numbers obvious with the wheel off? I didn't check that.
Next time I will look better, the shock numbers were stamped on the shock, so that was pretty easy to check. My build codes do not show a suspension change. I was thinking, maybe the shock on that wheel has or is going bad. I had not quiet a 1/2" clearance from tire to strut bottom, both sides, a 1/4" from backside of tire to strut. Car was on the ground when I checked it.
Old Hippie Young Heart
jcb986 is offline   Reply With Quote
