Old 11-12-2013, 10:38 AM   #21
Originally Posted by Bigsmoothlee View Post
I agree 100%. You can buy the original one from Porsche for $112, I dont see what the big fuss is to change it every time you replace the clutch...
I think a lot of it comes from aftermarket companies that have bills to pay and families to feed too.
Granted, certain years have had issues, but not ALL generations.
Ive said I was in the market for 97-99 and all I got was "you better upgrade the IMS asap...."
Those years didn't have an issue, but "I better change it out pronto and spend 3k" or whatever.
If the car has miles on it and the IMS is fine, why even change it at all?
Of all the cars Ive owned, of all the car boards ive been on, Ive never seen people so eager to replace parts that aren't broken.
evomind is offline   Reply With Quote
Old 11-12-2013, 10:53 AM   #22
You sound very well versed on the topic.
I suggest you do a little more research on what actually occurs when the non-broken parts do actually break.
Old 11-12-2013, 11:00 AM   #23
The motor pops.
If, if, if.....If the queen had balls she would be the king.
The 97-99 cars, and any other car have just as much chance breaking a rod as grenading an IMS.
Are you gonna tear down your engine tomorrow?
Have you researched what happens if you break a rod? Or wrist pin? Or piston?
The list goes on.
Watch out for lightening too.
Look, im not saying there isn't cause for concern for CERTAIN years, so be it, take cautionary action. But to have that same urgency on every Boxster ever built is just paranoia.
I stand behind what Ive said.
Old 11-12-2013, 11:15 AM   #24
Perfectlap's Avatar
These engine have peculiarities, specific needs and some uniqe rewards. Otherwise everyone would be driving something cheap to run.
Also, this is a sealed bearing in an engine. No old school bearing lasts forever.
If you want to make it last forever, well there's some collateral damage you have to work into that risk equation.
Old 11-12-2013, 02:14 PM   #25
The OP has not mentioned how many miles and if it's on the original clutch. If a clutch is pending, it's a no brainer, just do the clutch a bit early and the IMs while you're there. If you are not close to needing a clutch, that's a tougher decision.
runjmc2 is offline   Reply With Quote
Old 11-12-2013, 03:12 PM   #26
Topless's Avatar
Correct, which is why I listed the Metzger name since many think that the 996TT motor is simply a forced induction variant of the M96 motors used in 986 and 996's. The engine used in the 996 Turbo is a derivative of the Metzger engine found in the Le Mans winning GT1 race car, it also has none of the supposed weaknesses associated with the standard 996 Carrera engine.......
The 996TT and GT3 Metzger does have other more expensive car-killing weaknesses that must be addressed for reliability and peace of mind. All cars have warts and a 996TT is no different.
Old 11-12-2013, 03:14 PM   #27
Beginner
Jamesp's Avatar
8% of single row IMS bearings fail. They all lose their grease over time (and engine cycles IMHO). Getting it replaced *might* not be or even *probably is not* necessary. Maybe. I bought my Box cheap because of a IMSB failure. I bought a used replacement shaft and have first hand experience with the 03 S bearing. It was in what has been termed the "first" stage of failure. I believe all IMSB are in the "first" stage of failure after the first thermal cycle of the engine. My advice is to replace that sucker ASAP. The only catch is that simply replacing it puts the engine right back where it started. There are vast strings on this board regarding options for other design options. Enter at your own risk. Oh yeah, you might want to start a collection from the folks who sing "don't worry, be happy" to fund your complete engine replacement. There is an 8% chance (likely higher due to lack of reporting) that an M96 engine will pop due to the IMSB. Don't be a statistic, replace it with a new bearing at a minimum, and pick a redesign after that to minimize risk. I'm down my own path on this and I think I've identified and eliminate the root cause of early failure. like all mechanical components, the IMSB will eventually fail, but I believe I have a method to stave that off using the original greased sealed bearing.
Old 11-12-2013, 04:07 PM   #28
Good Lord......If everyone took to heart what you guy a spouse regarding these cars we'd all be riding rickshaws. On behalf of Ferry Porsche et all I apologize, yes we have intentionally gone out of our way to sabotage our cars for 2nd and 3rd owners who expect nothing short of infinitesimal longevity. I give, don't buy anything, drive it till it dies and when it does please be surprised.................
Jake Raby, I have NO IDEA how you put up with it....................... Drama Over lol.
Old 11-12-2013, 04:51 PM   #29
woodsman's Avatar
Didn't you say, in a thread about 993's, that you were amazed at how many different ways Jake Raby has found the M96 can (and often will) grenade itself ( 21 and counting, I've heard)?
Old 11-12-2013, 05:05 PM   #30
I think it was 23 or maybe more, not sure but Jake will likely correct. The 993 is without a doubt a more robust motor, BUT, the main modes of failure on the M96 motors from what I've read are: IMS, Water Pump, RMS and AOS which I alluded to replacing earlier.
I then stated that replacing these known issues / wear items would likely result in a reliable / fun car for the money. Try buying a nice example of a 993 for what a 996 coupe could be had for.
My prior post was to let the OP'er know things can indeed be addressed, if he wants to or not is his call.
Old 11-12-2013, 05:10 PM   #31
pjq
Parker 986, WE have cars which Porsche claim are the most vulnerable to this IMS failure, based on who gets what under the IMS class action lawsuit.
I have a 2004 S, was the same bearing as you.
My car had 23000 miles when I bought it in Nov 2010, my car had 43,000 miles on it when the IMS failed with NO warning in Nov 2012. I had the oil changed regularly and the filter inspected. Matter of fact the oil and filter were changed only 5 driving hours before the bearing failed, about 4 days before the failure. My wife and I had been driving for about 4.5 hrs bound for North Carolina when we descided to stop for a break, the car was working great I kept the rev's 3200 +. Upon stopping at the stop sign the engine stopped?? When I restarted the engine it was the "Death Rattle". Scared the s--t out of me, my heart was in my stomach and my stomach was in my mouth. At the time I didn't know what that noice was but it just couldn't be good.
The resultant was a catastrophic engine failure due to a failed IMS bearing.
In 2010 before I bought the car, I did some research and read briefly about IMS. I had a PPI carried out and everything was good. When I got the car home I took it to the local indie shop for oil change and inspection and spoke to him about the IMS. He said just drive it and enjoy it the car was in great shape. Later that summer I took it to the closest Porsche dealership for oil change and inspection and they also told me the car was in great shape IMS was ok, drive it and enjoy it.
Point is my gut told me to change the bearing but others in the know told me otherwise.
I think at the time cost might have been about $2000 for IMS bearing change? Do you have any idea how much it cost to rebuild one of these engines, if it is rebuildable after an IMS bearing failure? Do you know how much a straight used engine cost (junk yard) if you can find one? Do you know how much a Porsche factory rebuilt engine cost? The answer is it starts at $6500 (junk yard) and goes up from there to over $20,000.
So Parker this has been a long rant but the point is, if you are asking the question on this forum you already know what your gut is telling you. Remember its your gut, your car, your research, your descision and the worst part your hard earned money, spend it wisely.
Old 11-12-2013, 06:03 PM   #32
Beginner
Jamesp's Avatar
You could do this, Bob Marley-Don't worry be happy - YouTube Just watch out for the ganja, or you could be proactive and treat this as a maintnence item. Just like changing the timing belts as has been mentioned before. Ignoring timing belts (on interference engines) has an identical outcome to ignoring the IMS bearing.
Old 11-12-2013, 06:24 PM   #33
Perfectlap's Avatar
the biggest for me is that once that rear end steps out/slides, it cuts power to the rear producing yet even more understeer on top of what you've already have to contend with. Solution: 996 GT2 Or get the commando version
In a perfect world you'd have a NA GT3 engine, in RWD, mid enigne platform...with the cooling pipes all nice and sorted.
This is the car Porsche should have been building long ago instead of making 29 variants of the street-engined Carrera.
Old 11-13-2013, 12:20 AM   #34
RawleyD's Avatar
It's what he does for what I assume is a "very good" living.
He gets paid very well for "putting up with it". lol :ah:
:ah:
Old 11-13-2013, 09:12 AM   #35
Engine Surgeon
This is a labor of love, nothing more.
For what they say, or the drama, well its like water off a duck's back. I learned a long time ago that if you aren't pissing people off, you really aren't getting anywhere.
US Patent 8,992,089 &
US Patent 9,416,697
Old 11-14-2013, 01:34 PM   #36
Well, lot's of different opinions. My '04 S is in the shop today for a new clutch, etc , and I decided to replace the IMSB while it's apart. If I decide to keep the car for the long-term I'll have the piece of mind that I've addressed at least THAT issue; if I decide to sell I think any potential buyers will know that they won't need to do it, and thus I won't have to discount the price for it. I hope that a buyer looking at a couple Boxsters may be swayed to buy the car with the best maint history, condition and all other things equal.
Last930 is offline   Reply With Quote
Old 11-14-2013, 01:50 PM   #37
Perfectlap's Avatar
Good on you. A car offered for sale with a specific mention of pro-actively replacing the IMSB is a buy signal of enthusiast-ownership. It's impossible to calculate but I'd be of the opinion that you fall into a very small % of total Porsches owned. Which is not necessarily to say that every enthusiast has done the swap. One of our forum members has over 300K miles logged and was still on the original bearing. But that was someone who kept up with very strict maintenance practices and didn't leave the car around to sit/rot, obviously with that sort of mileage.
Old 11-14-2013, 02:42 PM   #38
Beginner
Jamesp's Avatar
You did the right thing. You should ask your mechanic to pull the old bearing side seal and see what is inside - grease? oil? or some combination?
Old 11-14-2013, 04:03 PM   #39
Thanks so much for all the responses. My car is 10 years old and only has 39,000 miles on it, which tells me that my '03 S is an even better candidate for failure since it hasn't been driven all that much. It has original clutch. I do notice it going into 2nd gear a little hard, so maybe it is beginning to fail.
Buying a new engine would be a pretty difficult hit to my pocket, so I have decided to keep my appointment. I know I will be nervous driving it 3 hours to the mechanic, hoping there is no engine failure.
Do I want to spend money if I don't need to, no, but at least I will be able to sleep better.
'03 Boxster S Lapis Blue
'06 BMW 550i Jet Black
Parker986 is offline   Reply With Quote
Old 11-15-2013, 03:56 AM   #40
Parker,
Still waiting for the pictures of new wheels.
Enjoy
Van
