10-19-2013, 05:54 AM
I am my own mechanic....
Be honest....
How often do you close your seatbelt in the door jamb??
(Strap, not the belt)
I've not caught the belt in there but there's 5 spots at least from that.
'08 VW Touareg T-3 wife's car
10-19-2013, 06:10 AM
Autobahn Glanz
Never that I can remember.
10-19-2013, 06:13 AM
recycledsixtie
I have never caught the seatbelt/strap in the door/doorframe. There is sufficient tension to prevent this happening. It used to happen on my 99 Miata. Apparently there is a silicone spray you can buy to enhance the retraction function of the seatbelt.
10-19-2013, 06:27 AM
Theoretical propagandist
One to many times...and you know you've done it when you get the "THUNK" sound on trying to close the door. My next thought is...crap, did I take the paint off! I have probably done it a half dozen or so times. Mostly when I am in a rush.
10-19-2013, 11:26 AM
Never happened
99' with 3.4l engine. ROW tune. SAI delete
10-19-2013, 12:03 PM
Originally Posted by golonaus
Never happened
So how many times?
10-19-2013, 01:44 PM
That's the problem with these older cars. The retract function gets weak. I'd be interested in that spray that helps with the retraction.
Now days, I try to make it a point to hand feed the belt back into it's container when I unbuckle.
Glen
10-19-2013, 01:51 PM
Frequently...
10-19-2013, 01:57 PM
Never. I learned the silicone spray (nothing special; any cheap stuff will work) treatment on this forum and they retract like magic! Just spray a lot of it on both sides of the belts. Works like a charm.
10-19-2013, 02:24 PM
Guess the spring in mine is 'like-new' then. Never happened, yet anyway
10-19-2013, 02:33 PM
Too often, for sure.
I'm conscious of it now.
99 Porsche Boxster 986 3.8
85 Toyota Corolla AE86 F20C
12 Honda Accord
16 Mercedes C450 AMG
22 Tesla Model X Plaid
10-19-2013, 04:04 PM
Both harnesses and seatbelt no problem
10-19-2013, 04:57 PM
Never happens to me.
10-19-2013, 08:10 PM
Be honest...
No issues for me. Seat belt tensioner pulls it in quickly.
10-20-2013, 06:15 AM
Once for just about every Porsche I've owned.
10-20-2013, 07:07 AM
I'm seeing a pattern.
Need to research spraying lube down there. I have to feed mine intentionally through the seat loop.
10-20-2013, 01:35 PM
It's never happened to me at least a dozen times.
'99 black 986
10-21-2013, 08:31 AM
Never, but I have noticed it's starting to retract a little slower. I'm never in a hurry when I drive the Boxster :-)
10-21-2013, 10:43 AM
I had that happen with a prior car. I was able to unwind and remove the belt and wind the retractor another couple of turns then reattach and rewind the belt.
10-21-2013, 11:16 AM
Good advice!!!
