Old 09-16-2013, 06:53 AM   #1
heymanwatchthis's Avatar
Another vote for under drive pulley
Installed Pedro's 4" underdrive pulley. Wow, could definitely tell a difference! I recommend it, seems to have only benefits with no downside.
I had trouble getting pulley stud out so had mechanic use air gun, he removed it with no problem. Filling down the boss is easy and does not take away it's functionality. I will keep the original pulley in case engine ever needs to be locked TDC.
'01 986S: LN IMS, PedroBar, PSS9 coil-overs, underdrive pulley, 997 short shift, GT3 console delete, Crios muffler mod
heymanwatchthis is offline   Reply With Quote
Old 09-16-2013, 10:01 AM   #2
What that do Exactly ?
2003 Boxster S
The French Dude is offline   Reply With Quote
Old 09-16-2013, 11:10 AM   #3
woodsman's Avatar
An underdrive pulley slows the speed that the accessories turn at therefore reducing engine rotational drag which free's up HP.
Old 09-16-2013, 11:57 AM   #4
I sure do like mine. The old butt dyno said, "THIS THING'S GOT MORE POWER NOW!!!"
It's a great mod.
Old 09-16-2013, 08:31 PM   #5
com3dorm3's Avatar
+1
The UD pulley was the fix to the constant power steering issues (fluid spills) during autoX events.
2000 Boxster S
com3dorm3 is offline   Reply With Quote
Old 10-09-2013, 01:51 PM   #6
I am my own mechanic....
Timco's Avatar
Holy crap!!!
Instant HP off the line, right where you want more.
I can't believe they don't come this way. Lots of power.
Can't wait to do cat deletes. They should be in any day!!
'08 VW Touareg T-3 wife's car
Old 10-10-2013, 04:50 AM   #7
How much more HP are we talking?
2001 Boxster S - Triple Black -
Billy Boat Muffler
ROW M030 Suspension
LNE IMSB
PorscheBound is offline   Reply With Quote
Old 10-10-2013, 06:36 AM   #8
Timco's Avatar
Not sure, but very, very noticeable. An absolute must for a simple bolt on mod that gives so much. Can't imaging all that new power to the wheels still being absorbed by the engine components.
Old 10-10-2013, 01:42 PM   #9
In this thread (fourth post), engine builder Jake Raby says that he has measured +5HP at the rear wheels when using a UDP.
http://986forum.com/forums/general-discussions/37563-underdrive-pulley-questions.html
Old 10-10-2013, 02:36 PM   #10
Perfectlap's Avatar
none? hmm.. seems to go counter to racing logic.
How exactly is this part improved over stock?
Old 10-10-2013, 03:46 PM   #11
Timco's Avatar
New pulley is 4". Stock is 6" diameter.
Old 10-10-2013, 08:23 PM   #12
Ckrikos's Avatar
I didn't feel it did that much.
LB/GG/MB 02 2.7 sold
MB/GG 02 996TT
Old 10-10-2013, 08:41 PM   #13
Engine Surgeon
We see this number over and over again with the 4" pulley. The UDP is THE best bolt on for net gains available.
US Patent 8,992,089 &
US Patent 9,416,697
Old 10-11-2013, 05:39 AM   #14
Does it have any more/less impact on the 2.5/2.7 motors vs. the 3.2 motors, or is it a flat 5HP due the common ancillary components used on all engines?
98 Arena Red 986
Stroked & Blown is online now   Reply With Quote
Old 10-11-2013, 07:05 AM   #15
Perfectlap's Avatar
What's the second best?
p.s.
While you are(n't) endorsing products, do you mind sharing the make of the UDP that you use in your testing?
Old 10-12-2013, 02:45 PM   #16
I just ordered the pulley from Pedro. He said I should get it in the next few days. I'm looking forward to a couple of more horses.
Question for the class: I the bolt reverse thread or normal thread?
'99 Boxster Artic Silver/Red
'14 Subaru Outback
'06 EG Classic
'05 Sportster
Old 10-12-2013, 04:16 PM   #17
Engine Surgeon
p.s.
Its not commercially available.
US Patent 9,416,697
Old 10-12-2013, 09:11 PM   #18
Timco's Avatar
RHT. (Normal)
Should come with a new bolt. If. 4" you need a shorter belt.
Old 10-12-2013, 10:41 PM   #19
rp17's Avatar
Okay I'm sold on the Udp. But whats this about shaving down the boss? Can someone explain? This sounds like a must do for my Fall projects.
Old 10-13-2013, 03:08 AM   #20
Timco's Avatar
The boss sticks out far enough to almost touch the back side of the pulley. The belt surface just wraps around it on orig pulley.
The UD pulley will rub into the boss. It's belt surface is dead even with the boss. So I used a sawzall and cut mine off. It would take a while to file down. Cut off flush or slightly proud.
I do not suggest you use a sawzall unless you are skilled with one. I've been using them for many years.
