Old 09-16-2013, 07:33 AM   #1
steved0x's Avatar
Screw spins when closing the panel cover after changing my cabin air filter
I just changed my cabin air filter. Used a T25 torx driver, screw came out with no problem, got the plastic cover off, replaced the filter, but when I went to screw back in the T25 screw it felt like it pushed something out the bottom of the hole, and now it seems like there are no threads. It just spins.
I am not sure how to get under there to see, and the plastic cover feels pretty secure even without this screw (slotted at the front and under the side of the battery cover) so I just left it out for now, but I would like to replace it at some point.
Has anybody ever had this? Or gotten under there and put the backing piece back on that has the threads?
Thanks,
Steve
Edit:
http://dcauto.gotdns.com:4000/illustration/index/170020884
It is the screw right by the number 4. From looking at all the related screws on this assembly, it looks like they all have a clip on the back. I guess you are supposed to unscrew them partway and then rotate the plastic cover out of the way and back...
Old 09-16-2013, 04:07 PM   #2
Joe B's Avatar
If your talking about the torx screw, there's a well nut behind there that it screws into. That's what you pushed out the bottom. I used one from my motorcycle spare parts and it worked fine. I can't remember where the access was, but I remember it was easy to get to.
Google
Old 09-16-2013, 06:00 PM   #3
Steve,
The part you are missing is #13 in the diagram. There is one on each side.
Bryan topping is offline   Reply With Quote
Old 09-16-2013, 06:31 PM   #4
steved0x's Avatar
Thanks everybody. When I got home tonight I looked in the Bentley manual and it said only to loosen the screw... The 101 Projects doesn't say that... I'll know for next time, and someday I'll dig in and find the access to replace the backing nut.
Thanks,
Steve
Old 09-16-2013, 08:13 PM   #5
thom4782's Avatar
The nut - part number 999 500 092 00 - costs a buck or two. It sits in the hole. When the trox screw gets screwed in, it compresses the rubber nut so that the screw and the nut cannot pull out of the hole.
Worth purchasing two replacements from the local dealer or one of the on-line dealers.
Old 09-16-2013, 09:28 PM   #6
AKnowles's Avatar
That's what I did. Along with some blue, white, and pink inserts. Then I bought a few spares for the engine cover, the wheel wells, the under car covers, etc. Seems everytime you work on the car you find a missing screw, snap rivit, etc. so having spares just makes your life a little easier since the same parts get used in all sorts of places.
