08-31-2013, 11:00 AM
#21
Originally Posted by JFP in PA
Most likely either a worn throw out bearing, or a weak input shaft bearing on the gearbox.
JFP:
Could be possible to replace the input shaft bearing by removing the transmission case but leaving the gearbox installed..?
In some gearboxes, the casing for the input shaft bearing is cast inside the transmission housing.
09-03-2013, 11:56 AM
#22
Deja-Vu..?
JFP, somehow I may have asked this question previously, if so please ignore..
And they say "that stuff is not bad for you"
...sure LOL
09-03-2013, 02:08 PM
#23
Exactly. If you do have a single-mass flywheel, that could do it as well.
Boxster S
04-09-2017, 07:59 AM
#24
Don't want to hijack the thread but my 02S is at the transmission shop with the exact same issue.
I bought the parts. Clutch,Pressure Plate,Throw out Bearing, Flywheel, Transmission parts for 2nd gear issue.
Did anyone come out with a fix? I am wondering if the throw out bearing was bad out fo the box.
Thom
04-09-2017, 10:58 AM
#25
It's the throw out bearing. You should have heard the one in my former E30 325is(with a new clutch)-it sounded like it had rocks in there with the clutch out.
04-09-2017, 11:14 AM
#26
Thom
Thom, do you mean the infamous bearings for the 6 speed (also on the 996)and the worn tooth problem for 2nd gear pop-out? If so this is an increasingly common problem with higher miles .It would be very useful to us if you could share details. If you are just using a detent or shift arrestor, I hope you took our advice and chose the best part?
04-09-2017, 03:44 PM
#27
Numbersix - I bought a Sach kit with the throw out bearing. Think it is bad out of the box?
Gelbster - My second gear would pop out and grind going into 2nd gear. Once they tore the transmission apart here are the parts they had me get.
999-917-546-00
Transmission Oil Man
996-302-942-00
Idler Gear 2ND
986-303-010-00
As Gearshift Rod
996-303-301-00
Spiral Clamping Pin
996-304-061-03
As Guiding Sleeve
996-304-611-00
Synchronizer Ring
996-304-613-20
Cone Ring
950-304-617-20
Synchronizer Ring
996-301-805-00
Shaft Sealing Ring
04-09-2017, 03:57 PM
#28
Wow ,that is an expensive shopping list[ I hope they are experts in this 6 speed 7/or the similar Audi 'box ? This is a very difficult unit to work on for the first time. Suggest you Search here nd in 996 Forums for Gearbox repair/rebuild. It is a task very few shops are qualified to tackle. A few of us have tried with some success but the task was very exacting for even experienced diy mechanics with deep pockets.
QUOTE=no1tmorrow;533248]Numbersix - I bought a Sach kit with the throw out bearing. Think it is bad out of the box?
999-917-546-00
996-302-942-00
Idler Gear 2ND
986-303-010-00
As Gearshift Rod
996-303-301-00
Spiral Clamping Pin
996-304-061-03
As Guiding Sleeve
996-304-611-00
Synchronizer Ring
996-304-613-20
Cone Ring
950-304-617-20
Synchronizer Ring
996-301-805-00
Shaft Sealing Ring[/QUOTE]
04-09-2017, 06:01 PM
#29
The throw out bearing is a new Sach bearing. I guess it could be bad out of the box. Do you all know there is anyway to test the bearing?
04-09-2017, 06:07 PM
#30
I bought all the parts from sun set porsche parts for 1650.00ish(shipping is a little much)
Reason: web
04-09-2017, 07:11 PM
#31
If you like free shipping , try RND Euro Parts. Good prices too.
