					Originally Posted by  no1tmorrow
				Don't want to hijack the thread but my 02S is at the transmission shop with the exact same issue.
I bought the parts. Clutch,Pressure Plate,Throw out Bearing, Flywheel, Transmission parts for 2nd gear issue.
Did anyone come out with a fix? I am wondering if the throw out bearing was bad out fo the box.
Thom
Thom, do you mean the infamous bearings for the 6 speed (also on the 996)and the worn tooth problem for 2nd gear pop-out? If so this is an increasingly common problem with higher miles .It would be very useful to us if you could share details. If you are just using a detent or shift arrestor, I hope you took our advice and chose the best part?
