07-17-2013, 11:07 AM
Durametric fault code question
Getting these two codes:
PO139 - Fault Code 17 - Sensor ageing behind cat converter cylinder (1-3)
PO140 - Fault Code 12 - O2 sensor behind cat converter cylinder (4-6)
Car is a 2002 S
These are just for bad 02 sensors, right? Nothing about the cat itself? Just replace the two sensors? And does behind mean before or after the cat?
Thanks for the help
07-17-2013, 11:42 AM
Car is a 2002 S
Thanks for the help
Maybe, or maybe not. P0139 is indication of an aging (read dying) sensor behind the three way cat on bank 1-3. That said, P0140 is indication of an interruption of signal from the same sensor, which is often a wiring or connector issue.
I would use the Durametric to read the voltages for the sensor to see if they are in range, if they are, you may want to check its harness for problems.
07-17-2013, 12:00 PM
Aren't the faults for two different banks?
07-17-2013, 12:35 PM
Car is a 2002 S
When the CAT starts to fail you will get its own code saying that its not efficient any more or something like that.
07-17-2013, 12:50 PM
07-17-2013, 01:15 PM
Yeah, you've got a problem. First of all, this is what a good before and after sensor set should look like:
When the main three way cat goes bad, the sensor behind the cat starts following the voltage curve of the one ahead of the cat, because the cat is no longer converting the gases:
In your case, it does not look like the cat (yet), but more like the signal is interrupted or inconsistent, which would be more likely a wiring or electrical issue.
07-17-2013, 01:29 PM
could it be the connector on the O2 sensor?
07-17-2013, 01:52 PM
Yes, could be lose or corroded, could also be frayed wire somewhere in the harness.
07-18-2013, 06:56 AM
Thanks for the help
10-21-2013, 05:02 PM
Now I'm getting 1128 and 1130 after replacing the o2 sensors behind the cat
10-21-2013, 05:59 PM
Codes are for the same problem on both banks: System has reached its enrichment limits. Usually a sign of an air leak in the intake, low fuel pressure and/or delivery volume.
10-22-2013, 06:35 AM
what about the MAF?
10-22-2013, 10:06 AM
what about the MAF?
Codes are not related to the MAF, which in any case has minimal impact on how the engine runs below about 3,500-4,000 RPM, and the car will actually run fine with the MAF unplugged.. The codes are very specific, the car is running lean on both banks and the DME cannot richen the mixture up any further. Air leaks and fuel delivery problems are the most common cause for both codes.
01-25-2014, 08:58 AM
Re-read the above again............................
10-22-2013, 11:16 AM
Makes sense, thank you
10-22-2013, 01:13 PM
10-22-2013, 01:14 PM
10-22-2013, 06:42 PM
MAF values reading low
01-25-2014, 07:24 AM
getting the codes again after replacing MAF, O2 sensors and AOS
what's next on the list?
01-26-2014, 07:07 AM
Yes, which one first. Neither are easy without the right testing equipment for a DIY, right.
Would either air leaks or fuel pressure/delivery be more likely?
