Maybe, or maybe not. P0139 is indication of an aging (read dying) sensor behind the three way cat on bank 1-3. That said, P0140 is indication of an interruption of signal from the same sensor, which is often a wiring or connector issue.
I would use the Durametric to read the voltages for the sensor to see if they are in range, if they are, you may want to check its harness for problems.
Aren't the faults for two different banks?
