Old 07-13-2013, 04:49 PM   #1
Verhag's Avatar
Help - Center wind deflector release?
Ok,what am I missing here. Just bought a 2000 Boxster S. 75,000 miles, trying to remove center wind deflector....I try to lift one lever up, then the other....neither "flip" up like am expecting...don't want to break it, what am I missing? I've searched.
1997 C4S
2000 Boxster S
Verhag is offline   Reply With Quote
Old 07-13-2013, 04:57 PM   #2
ccjazz's Avatar
Try lifting one of the two locking levers, hold it open while pushing down on the windstop and pull it towards the rear out of the fastening point on that side. Repeat for the other side.
'01 Boxster S (purchased new) triple black, litronics, cruise, heated seats,18's.
ccjazz is offline   Reply With Quote
Old 07-13-2013, 05:11 PM   #3
Verhag's Avatar
Should the locking lever flip up...say 90 degrees or more? There a smaller lever inside of the main release lever... Is this the locking lever? Sorry, for my ignorance, but don't want to force and break.....
1997 C4S
2000 Boxster S
Old 07-13-2013, 05:55 PM   #4
ccjazz's Avatar
No, not 90 degrees....only half an inch or so, you might break it otherwise. Make sure you push down on the top edge of the windstop at the same time and gently push towards the rear of the car. You'll get it...patience.
Old 07-13-2013, 07:35 PM   #5
Gforrest2's Avatar
Yup, the key is pushing it down and then back as you hold the release lever down. The lever just goes down a little bit. Do one side at a time as suggested above.
Glen
