Old 07-15-2013, 02:40 PM   #21
woodsman's Avatar
definitely a neat car- the wheels match the rest of it perfectly.
Old 07-16-2013, 09:48 AM   #22
aclark133's Avatar
Are you saying a VW 1.8T is a direct fit to the boxster transaxle?
aclark133 is offline   Reply With Quote
Old 07-16-2013, 09:51 AM   #23
aclark133's Avatar
Also the 225 TT has 2 side mount air/air intercoolers
Old 07-16-2013, 10:03 AM   #24
The Radium King's Avatar
the boxster 5-and 6-speed transaxles are interchangeable, and the boxster 5-speed transaxle is a repurposed audi 012 unit so I assume complete compatibility (you would have to turn the engine 90 degrees).
regarding intercoolers, I think standard practice on boxsters is to use an air/water unit and repurpose the centre radiator as a heat exchanger for the intercooling. kpaz found on his 400 + hp 4-pot subi conversion that he had more cooling than required, so I assume that the middle rad wouldn't be missed on the 1.8t conversion.
Old 04-10-2019, 05:47 AM   #25
Just put over 100 miles on my 1.8t 1999 Boxster. I'm using the stock transmission, the gearing works out great with this turbo engine. I have a tuned APR tuned ECM, so the power should be about 200HP. I did have to put a little bump in the top engine cover to clear the engine but the roof still opens and closes without problems. I still need to find a solution for making the 6cyl tach work with the 4cyl engine.
xoo00oox is offline   Reply With Quote
Old 04-10-2019, 07:12 AM   #26
where's the PICS!
L1ttleBastard is offline   Reply With Quote
Old 04-10-2019, 07:45 AM   #27
[IMG][/IMG]
Old 04-10-2019, 08:55 AM   #28
I also put an identical 1.8t and 5 speed transmission, also tuned to about 200hp. It's a blast to drive.
Old 04-23-2019, 11:14 AM   #29
What are you guys typically getting for fuel mileage with your stock engines? While I haven't actually checked it yet, I seem to be getting great fuel mileage with this 1.8t entgine, I'm guessing around 30mpg or better. I'll check it over my next full tank of fuel.
Andrew-
Flint European Auto.
Old 04-24-2019, 01:46 PM   #30
kirkandorules's Avatar
Andrew-
This is very impressive! I'm usually in the upper 20s in my 2.5. Strangely, highway vs city doesn't seem to make a huge difference for me, nor does driving at high RPMs for longer periods of time.
My 1.8T Golf gets 35-40 hwy and 30ish city.
'99 986 Ocean Blue Metallic
'87 924S, winter beater
'17 VW Golf Sportwagen, for when I need extra seats
kirkandorules is offline   Reply With Quote
Old 12-31-2020, 12:30 PM   #31
ksjohn's Avatar
Reviving an old thread here.
Has anyone else done an engine swap with a VW 1.8t engine? I want to do a project car with an alternative engine that can be pushed to around 300hp. The 1.8t seems like a good fit due to cost, comparability with the 5 speed tranny and performance upgrades. I know one guy in NY did this about a year ago. Any additional info would be appreciated.
ksjohn is offline   Reply With Quote
Old 12-31-2020, 01:15 PM   #32
Qingdao's Avatar
[/IMG]
That exhaust is just wrong looking. LOL nice build.
'98 PP13B powered "RX986"
