Old 06-29-2013, 07:10 AM   #1
tomc88's Avatar
Boxster S short shift gear selector
on my 2001 Boxster S
I lifted the 'leather skirt' around the base of the gear stick;
underneath some of the metal parts of the shift linakges are anodised blue metal.
This looks just like some of the 'short shift' gear linkages you see on eBay etc.
so, has mine been upgraded, do you think?
or is the standard Boxster S gear linkage blue like this?
This is my first Porsche, so I have no idea what the gear stick throw is, and whether it's standard or short shift!
thanks
2001 Boxster S
tomc88 is offline   Reply With Quote
Old 06-29-2013, 12:54 PM   #2
ChrisZang's Avatar
looks like a short shift kit to me
Old 06-29-2013, 02:21 PM   #3
Moderator
Your suspicions are correct; it is indeed a short shift kit. I installed the same one in my car a while ago.
Old 06-29-2013, 03:13 PM   #4
tomc88's Avatar
ok, I guess that's good then.
well all I can saw is wow! the standard gear shift must have very LONG throws....
my car also has some sort of upgraded manifold.... improved efficiency maybe (my mechanic pointed it out)
2001 Boxster S
Old 06-30-2013, 05:42 AM   #5
Not the full short shift kit. Looks like just the bushings. The white plastic piece the shift handle go through is metal on mine.
Van914
Old 06-30-2013, 07:09 AM   #6
golonaus's Avatar
these R just bushings
lever travel is stock with them
so it not real short shift kit
Old 06-30-2013, 07:55 AM   #7
As others have said you have a mix of parts. The end pieces with the bushings look like identical to what came with my Schnell SSK, however, the center piece on my SSK is also blue anodized aluminum. The previous owner probably switched it back to the stock shifter at sale time (or previously if he/she disliked the ssk)and had no choice but to use the aftermarket bushing as removing the crappy factory bushings necessitates destroying them...
shadrach74 is offline   Reply With Quote
Old 07-01-2013, 12:00 PM   #8
HammerESQ's Avatar
I believe I saw the upgraded bushings without a short shift kit on Pelican or Vertex, for people who wanted to keep a stock shifter throw, but upgrade the bushings.
HammerESQ is offline   Reply With Quote
