Old 02-11-2015, 03:22 PM   #1
Auf los!'s Avatar
Thanks! The BBS CH-Rs are 19x8.5 front and 19x10 rear. The Michelin Pilot Super Sports are 225/35R19 front and 265/30R19 rear. These are the "standard" +2 sizes which are very close to the original diameter. No rubbing issues whatsoever, but the car is not lowered. To my eye, the offset of the wheels made the fronts seem a little too inboard, so I use 5mm spacers, just on the front.
2001 Boxster S 6-speed, 2013 Boxster S PDK
Auf los! is offline   Reply With Quote
Old 02-13-2015, 02:56 PM   #2
Nice looking, looking nice! Thanks for sharing
2001 Seal Gray Boxster (Hair Salon on wheels)
2013 Audi Q5 (Family Mover)
2006 Yamaha R1 (Adrenaline Machine)
amitmishra4 is offline   Reply With Quote
Old 02-13-2015, 05:05 PM   #3
Auf los!'s Avatar
Thank you, thank you.
Laflamme, the shift knob may be technically "aftermarket," but it is a factory knob, very similar to the 996 standard knob, but with a tiny Porsche crest. Back in 2001, when my car was built, you could specify that this very knob should be installed. Pretty as it is, though, it is much shorter than the original knob, and therefore has to be moved that much less, resulting in quicker shifting.
I have always felt that the shifter in the 986 was and is the poorest-engineered part of the car. I spent more than ten years shifting a 1999 Miata, you see, and that experience spoiled me forever, shifting-wise.
To me the original shift knob seemed way too long, making the shifts that much longer. So first I tried this Porsche Exclusive-department knob, and it was better, but not good enough. So I then tried the 997 shifter, and that wasn't good enough. Lastly I installed a B&M shifter, and in conjunction with the shorter shifter, it's giving me shorter shifts, but is still nowhere near as good as a Miata shifter.
The Miata shifter shaft descends directly into the transmission, whereas the Boxster shifter is connected to two 10-ft cables, so maybe a Boxster shifter is NEVER going to be as direct-feeling and short as a Miata. But a Porsche deserves to have an excellent shifter, so I've been eyeing the Numeric Racing shifter, but, jeez, it is expensive.
Old 02-13-2015, 05:13 PM   #4
More's Avatar
Hot wheels and tyres.
The sticker goes really well with that coloured car.
Nice Work!!
1998 Porsche Boxster 986 Convertible.
More is offline   Reply With Quote
