Old 06-07-2013, 07:58 PM   #1
Do you cool your engine down after a drive?
Who else is crazy like myself and do this to their car at the end of the day? I've been doing this for years now. My theory? Keep the Eng compartment cool will keep things from getting too brittle.
2008 Boxster S PDE2
cas951 is offline   Reply With Quote
Old 06-07-2013, 08:06 PM   #2
Multi-Boxer Driver
Deserion's Avatar
On my previous turbo cars, I'd generally drive leisurely for a while to let them "cool" down. I do the same on the Boxster if it's been run hard, but haven't used the fan method aside from the times I wanted to cool the engine bay on the E320 to do work.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 06-07-2013, 08:34 PM   #3
Maybe you're cooling things down too fast and making them brittle...
Old 06-07-2013, 08:47 PM   #4
Once they are cooled my next step is this. Yes my wife used to laugh at me but she does the same process now. She places the fan right where it belongs.
The two in the garage a driven only on weekends. The blk one is driven daily.
2008 Boxster S PDE2
Old 06-08-2013, 03:11 AM   #5
I broke out a fan on my Boxster last weekend the same way you did, and also wondered if others did the same. Seems like it's the only way to keep air circulating once the car has been shut down and sits, essentially baking, in the garage.
All of my other cars are front engine, and during the summer TX heat season, I have always backed them into the garage and popped the hood, which allows all of that heat to escape from the engine bay.
My next step for the Boxster may be a larger floor fan to circulate air under the car while a smaller one is aimed at the intake.
ATX_Boxster is offline   Reply With Quote
Old 06-08-2013, 05:21 AM   #6
Theoretical propagandist
Eric G's Avatar
I whisper sweet nothings to it before I drive to get it warmed up! So far it seems to be working. Cooling down has not been an issue however!
Old 06-08-2013, 05:36 AM   #7
This is my routine. I use a larger fan in front of the Box. It cools both front radiators and blows air under the car.
2008 Boxster S PDE2
Old 06-08-2013, 06:00 AM   #8
Yup. Bought this for the job, about $100 at Grainger. The Turbo really loves it. Not as much for the Boxster due to the hidden motor:
Old 06-08-2013, 06:13 AM   #9
Nimbus117's Avatar
After a 'spirited' drive, I normally take the last mile easy. I dont like the idea of thrashing an engine then just turning it off, the fan is a step too far for me though.
2003 Boxster 2.7L
2010 Civic Type R
Old 06-08-2013, 06:43 AM   #10
recycledsixtie
recycledsixtie's Avatar
+1 in this.
This thread forced me to look up engine cooling in the Owner's Manual. Page 63 explains the fans may continue to run or start to run. To me any other external fans are redundant.
Old 06-08-2013, 11:51 AM   #11
Topless's Avatar
I am less concerned about airflow and more concerned about hot oil flow. After a track session I always drive an easy lap or a few miles to cool down the oil, coolant and brakes. When I park the job is done.
Old 06-08-2013, 12:33 PM   #12
Keeping the engine compartment cool is generally a good thing. While I've never heard of parts failing due to brittleness from normal operating temps (ozone and plain old age are probably just as or more so damaging), I suppose if you have the time and the will to do this, go for it.
Old 06-08-2013, 01:49 PM   #13
And I thought I was OCD.
Seems excessive, but to each his own.
Old 06-08-2013, 04:23 PM   #14
Squozen's Avatar
Pointless IMO, but it's your money.
Squozen is offline   Reply With Quote
Old 06-08-2013, 05:56 PM   #15
Johnny Danger's Avatar
Is this the equivalent of a "happy ending" for a boxster ?
Old 06-08-2013, 06:24 PM   #16
O.C.D. XXL IMHO.
The manufacturers test these cars from the Gobi Desert to the Artic Circle.... If they're happy, I'm happy.....
Whippy is offline   Reply With Quote
Old 06-08-2013, 07:52 PM   #17
Hayden's Avatar
This is unnecessary, but I like that you like your Boxster that much. I'm way out of my range of expertise, but could changing the temperature of plastics quickly, rather than slowly, make them more prone to cracking due to the transition process being faster?
I think the main benefit here might be to cool it off as much as possible before sealing it in a garage, which thermally effects interior conditioned space of your adjoining home. Unless it's winter. Take advantage of that heat!
Hayden is offline   Reply With Quote
Old 06-08-2013, 09:19 PM   #18
Heating and then quickly cooling any material will make it harder and more brittle. A slow cool is almost always best, unless you're tempering glass. Whether a fan will cool things quickly enough to cause this is doubtful though.
Old 06-09-2013, 12:10 PM   #19
Nimbus117's Avatar
Brilliant!
2003 Boxster 2.7L
2010 Civic Type R
