Old 06-01-2013, 12:28 PM   #21
What's wrong is that it's only 7:03 am and it's already nearly 80 degrees out??
pharaohjb is offline   Reply With Quote
Old 06-01-2013, 12:31 PM   #22
CoBeerToad's Avatar
I tried. Nothing happened.
CoBeerToad is offline   Reply With Quote
Old 06-01-2013, 12:37 PM   #23
Damn Yankee
TeamOxford's Avatar
WE HAVE OURSELVES A WINNER !!!!!
Congrats to pharaohjb. Ever think of moving to Dallas?
TO
Old 06-01-2013, 06:35 PM   #24
80 is nothing.
We are triple digits at all times
Old 06-01-2013, 07:58 PM   #25
AKnowles's Avatar
Originally Posted by Crono0001 View Post
80 is nothing.
Good, someone I can ask about comparable coolant temps then. Often my coolant temps will reach the middle of the 0 in 100+ degree weather. Does yours do the same?
Old 06-02-2013, 06:12 AM   #26
Yep. When properly warmed up, the needle idles in the middle of zero.
And to prove I'm not exaggerating:
This is in my garage. As in, where it's cool.
Old 06-02-2013, 03:14 PM   #27
AKnowles's Avatar
Thanks. That makes me feel a LOT better as I was wondering if I still had a coolant issue or not.
Old 12-21-2013, 10:23 AM   #28
Damn Yankee
TeamOxford's Avatar
Third edition of "What's Wrong with This Picture":
What's wrong with this picture of the instrument panel of a 1997 Boxster with a stock 2.5L engine, currently listed on eBay:
TO
Old 12-21-2013, 10:34 AM   #29
BYprodriver's Avatar
TO
Indicated RPM seems implausable
Old 12-21-2013, 10:37 AM   #30
The MPH should be in the speedometer window and the odometer should be in the tachometer window... At least that is the configuration on my Boxster. Looks like there are display options I did not know about.
1st pic is a 1996-2000 IP it has the larger MPH digital readout in the tach. One of the reasons I bought a 2000.
Old 12-21-2013, 11:34 AM   #31
Surely you wouldn't try to use the time thing again.
03 boxster
Rickinduncan is offline   Reply With Quote
Old 12-21-2013, 05:11 PM   #32
Damn Yankee
TeamOxford's Avatar
You are correct, sir.
TO
Old 12-21-2013, 07:25 PM   #33
TO
I'm correct that you wouldn't or I'm correct that it is. I suppose I'd be right no matter how you answer.
03 boxster
Old 12-22-2013, 11:17 AM   #34
out of oil
it's the low oil indication. Mine shows the oil level after the counter is done. It doesn't drop to "no oil".
Old 12-22-2013, 11:19 AM   #35
TO
Idiot is over revving the engine! The 2.5l if redlined at 6400 or 6500! I wouldn't buy the abused car!
Old 12-22-2013, 01:09 PM   #36
Damn Yankee
TeamOxford's Avatar
Three things struck me when I initially saw the picture in the ad.
Most serious was the engine registering 1000 RPM over the indicated redline. According to the text of the ad, the “car was babied never raced or mistreated…”. Don’t know about that, but then again, this “car will not last long”. I’d probably believe that statement.
Since the car was revving under no load, it may have been just a split second over-rev, and the camera caught the tach needle at just the right time.
Remember now, these pics come from actual ads. They’re posted by people trying to sell these cars, so you would think they would perform some due diligence and actually look at the pics they’re posting.
I did notice that the time was off. Don’t know of any place where the sun is shining high in the sky at 5:06 in the morning. Well, maybe near the poles at certain times of the year, but then again, those places never see 84 degree weather.
Lastly, the temp is climbing above 180 degrees which is probably no cause for concern, but..........I’m just sayin’……………..
TO
