What's wrong with this picture?
From a craigslist ad I saw today:
http://986forum.com/forums/uploads01/Oil1370040740.jpg What's wrong with this picture? TO |
The oil level counter has stopped and its reading zero oil?
Oxford - thats the US spec diesel engined Boxster - only revving to 6,400rpm......
Should be redlined @ 7,200rpm if I'm not mistaken. |
What's the orange light/sticker above the seatbelt one??
That's the CEL
That tach is for 2.5 |
The MPH should be in the speedometer window and the odometer should be in the tachometer window... At least that is the configuration on my Boxster. Looks like there are display options I did not know about.
Jäger, it's not a display option, it was that way on earlier boxsters.
Isn't that the high temperature warning light that is on in the temp gauge, while the gauge reads low temperature? That can't be normal?
The lights are all on because its Key On Engine Off...They will all be illuminated until the engine is off, then the car will run its monitors and turn off all the unnecessary lights.
I'm still betting on the its out of oil theory. |
Mine does out of oil when I first turn the key.
This is basically my head unit. I can't spot anything |
Mileage looks Photoshopped.
Oil level indicator not showing any level is normal while the countdown timer is displayed (showing 2:41 in the photo). This indicates that you need to wait 2 mins and 41 sec until the oil level measurment is valid.
C'mon Oxford, who's the winner - don't be shy.......
The only thing I can see that is different to mine is the outside temp gauge under the mph, which I don't have, and the airbag light goes out very quickly, and there is no roof light, but I am not sure if that stays on at all until you start her up.
Here's a shot of my dash under basically the same conditions: http://986forum.com/forums/uploads01/Bars1370092943.jpg Notice that some of the bars in the oil level gauge are illuminated. As you know, they will all flash on and off until the timer reaches zero. My thought was that the gauge was faulty. But since the bars are flashing, could it be possible that the picture was snapped at the exact same instance that the some of the bars were turning off, and just before the next set of bars were turning on? Well I'll be darned if I didn't replicate that also: http://986forum.com/forums/uploads01...1370093197.jpg So........what's wrong with the original posted picture? Maybe nothing, but I sure thought it was funny that the owner of the Boxster would post a classified ad for the car with a picture of an oil level gauge that read zero. Thank you all for playing; it was great reading all your responses, and we'll see you all again on the next edition of "What's wrong with this picture?" :) TO p.s. What's wrong with this picture: http://986forum.com/forums/uploads01/Temp1370093682.jpg |
you've got two idiot lights on!
the spoiler, which goes off when the car starts moving. the parking brake, which goes off after release. |
| All times are GMT -8. The time now is 08:27 PM. |
