Old 05-27-2013, 08:04 AM   #1
The clamshell is fine, it sits flush all the way around. The corresponding small piece on the right side sits perfect but the left sits a bit high. I will try to get some better pictures posted.
Bryan topping is offline   Reply With Quote
Old 05-27-2013, 10:53 AM   #2
jaykay's Avatar
It looks like the clamshell "tips" are stopping too far down. You adjust the stops underneath a few clicks at a time until the shell is level. You may want tips a hair below the "tab" piece so that you don't get them whistling in the airstream.
The stops look like black plastic strips underneath the shell tips. As I recall you slide and click them to raise or lower the stop position. You can get to them with the shell up in service position
One day I had some garage time and started fiddling...sorry I can't refer you to a manual peocedure
986 00S
Old 05-27-2013, 12:30 PM   #3
Time to get the hammer out!
'99 Boxster Artic Silver/Red
'14 Subaru Outback
'06 EG Classic
'05 Sportster
Old 05-27-2013, 04:24 PM   #4
that was my first thought too but figured to go careful in case I broke something as expensive as an anatomical appendage
