Old 05-08-2013, 05:02 AM   #1
Who is the best company for oil analysis?
Well, I changed the oil for the first time in my newly acquired 1998 Boxster (27k miles). I'm considering sending the oil off for analysis. Who do you recommend? What is the best method for sending your oil. I've owned many "sports" cars over the years but I've never felt the need to send off the oil for analysis so this is new to me.
Meat Head is offline   Reply With Quote
Old 05-08-2013, 05:52 AM   #2
Multi-Boxer Driver
Deserion's Avatar
Blackstone Labs
They send you the necessary packaging to send them an oil sample. Analysis isn't overly expensive, and a lot of people seem to be satisfied with the service they receive.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 05-08-2013, 06:01 AM   #3
I use Blackstone. I buy in bulk of 6 tests. Runs about $21 per test this way. I also do UOA's on my transmission/gear lube.
I would not suggest sending them a sample from your most recent drain, because it is probably contaminated from whatever you drained it into, unless you took this into account, prior. Maybe your next oil change.
Lastly, one test won't tell you much. So, if you start doing them, continue doing them to see the data and direction your engine and oil choices are taken.
Old 05-13-2013, 05:40 PM   #4
JB3
Ditto. Blackstone is great
JB3 is offline   Reply With Quote
Old 05-13-2013, 06:04 PM   #5
DFW02S's Avatar
I use Blackstone too.
DFW02S is offline   Reply With Quote
