05-10-2017, 04:46 AM
#501
Originally Posted by kdbroad
Hello,
I also need help with the code for my Becker.
Type: CDR220
Model No.: BE 6625
Serial No.:15006390
Your help is much appreciated.
-K
Try 3237 first and if that doesn't work try 3236
Heiko
https://greatcyclechallenge.ca/Riders/HeikoVoss
Previously owned:
05-10-2017, 09:36 AM
#502
I have a 1999 Boxster with a CDR 220 radio needing a code. After a HILARIOUS experience dealing with a dead battery behind an electronic locked trunk I'm left with no ability to play the McGuyver soundtrack, which is how I feel after getting to that frickin battery.
Type 4462
Ser. W5011240
Your help is appreciated!
05-10-2017, 10:36 AM
#503
Type 4462
Ser. W5011240
2483 is your first choice and if that doesn't work try 2482
Cheers
Heiko
Previously owned:
05-10-2017, 04:36 PM
#504
Originally Posted by Heiko
First one worked! Sweet!
05-11-2017, 07:07 AM
#505
serial number 25012832 cdr-220
thanks Darren
05-11-2017, 07:09 AM
#506
Serial 25012832 Cdr-220
Code please?
Thanks Darren
05-11-2017, 09:05 AM
#507
Code please?
Thanks Darren
Try 6518 first (that one should be good) if not try 6517
Heiko
Previously owned:
05-11-2017, 11:12 AM
#508
Works fine. Thanks so much.
-k
05-11-2017, 03:34 PM
#509
your the king!
05-16-2017, 11:07 AM
#510
Sarah's Tool
In Search of . . .
Hello there Mr. Heiko:
We finally fired up my wife's Boxster and neither of the codes below worked.
Please help!
Sarah's Main Tool
Originally Posted by Sarah's Tool View Post
Hello Mr. Heiko:
Here's the dope: CDR220, GAL1, 4462, Y5034552, 24/99.
How'd I do?
I see you got the info
try 9260 first and if that doesn't work try 9248
H
Heiko's PCAR Motorsports [/I][/B][/I][/PHP][/PHP]
Sarah's Tool
2000 Boxster S - the Black Bullet
05-17-2017, 09:07 AM
#511
Please help!
Sarah's Main Tool
Hello Mr. Heiko:
How'd I do?
H
For the CDR220/4462 ending in serial 4552 the code options I get are 9260 and 9248
Those are the only numbers coming up.
Heiko
Previously owned:
05-17-2017, 06:46 PM
#512
Heiko
Hi there,
I've lost my code as well. Greatly appreciated if you can find it?
CR220
Type 4362
SCR is, 15004778
05-17-2017, 06:56 PM
#513
Originally Posted by Pominoz
Hi there,
CR220
Type 4362
SCR is, 15004778
9041 should work fine :-)
Heiko
Previously owned:
05-17-2017, 07:37 PM
#514
That's great thanks! I'll try it on my garage queen tonight 😁
05-17-2017, 09:05 PM
#515
Lost code
Hi there,
I've lost my code as well!
CR220
Type 4462
Serial: X5030603
or X5030833 (sorry the sticker is crumpled a bit)
Thanks You!
05-18-2017, 04:05 AM
#516
Originally Posted by 7nate9
Hi there,
CR220
Type 4462
Serial: X5030603
Thanks You!
Man double work
If it's X5030603 code is 4313
If it's X5030833 code is either 0491 (1st) or 0489 (2nd)
Heiko
Previously owned:
05-18-2017, 06:57 AM
#517
To all of you that are getting codes from Heiko...... be sure to check out the below link. Anything helps. And, he is so close to his goal for such a great cause. Come on folks.... PayPal $5 or $10 for a code!
1995 Porsche C4 Cab
05-21-2017, 02:15 PM
#518
Hi again!
The codes didn't work for me and I learned that you can check for the serial number via the tp button. I gave you the wrong serial
Type 4462
X5030683
Sorry for bothering you and thank you soo much!
Regards,
Nate
05-24-2017, 12:52 PM
#519
Hi again!
Type 4462
X5030683
Regards,
Nate
Usually the safest way to look it up is by the tp button menu :-)
Ok your code is 8537
That should now work for you
Heiko
Previously owned:
05-26-2017, 03:58 PM
#520
Help Please with Code Boxster S 2002
Hi Mr. Heiko,
I would be grateful if you could help provide code for becker type 4462, serial number 25010654
Thank You,
Peter
