Old 05-06-2013, 10:07 AM   #1
The Radium King's Avatar
universal engine stand
hi - will a universal engine stand work with a m96 motor, or do I need an adaptor?
Old 05-06-2013, 10:28 AM   #2
Depends upon the stand, some have a problem getting the mounting arms in tight enough to hold an M96/97 case, other are fine. If the arms don't work, you can get a specific adaptor:
Old 05-06-2013, 05:33 PM   #3
Porsche "Purist"
Paul's Avatar
Some work, but not a workable solution if you need to split the case.
[IMG][/IMG]
1987 924S. 2002 996TT. PST-2
Old 05-06-2013, 06:43 PM   #4
BYprodriver's Avatar
Here's a pic of 1 of the 2 different designs I use, both are configured so that you can mount the 1-3 cyl case half with 3 bolts as seen in the picture below:
When it's time to install the 4-6cyl case half, just add the 4th leg & bolt to the 4-6 case side.
