Old 12-06-2005, 04:52 AM   #1
"and spray the cover with cats propellant"
Black powder, gasoline, lighter fluid - any of these would make a good propellant. Then all you need is a confined space to act as a barrel, and voila, airborne cat. Problem solved.
I'd go with the cover.
Not on this car, but I have had cats that would crawl up in the warm engine compartment to sleep (Older american cars that USED to have enough room around the engine to actually reach things). The bottom ground effect panels should prevent that on the Box.
limoncello is offline   Reply With Quote
Old 12-06-2005, 05:43 AM   #2
Ronzi's Avatar
Scratches come in on little cat feet.
Frankly I would be more concerned about them raising cain with the paint. At least a top can be replaced cheaper (but not by much).
Ronzi is offline   Reply With Quote
Old 12-06-2005, 07:05 AM   #3
Brucelee's Avatar
Yes, cats can and will scratch the paint. I would cover the car as suggested.
Alumium foil will keep them off the roof.
Good luck
Old 12-06-2005, 07:47 AM   #4
tqtran's Avatar
Go out and buy an Airsoft gun (230fps or more). Walk up like you are going to pet the cat and shot it at point blank. It will never come back again Don't ask me how I know this works
edit: an Airsoft gun is a toy gun that shoots plastic BBs. It won't kill anything.
tqtran is offline   Reply With Quote
Old 12-06-2005, 12:52 PM   #5
bmussatti
Guest
Posts: n/a
Maybe you need to get a pet dog...a really big dog! A really big hungry dog.
Maybe I don't understand garages in California, but how about getting a door put on that garage.
Old 12-06-2005, 01:07 PM   #6
cnk
Thanks for all the advice.
To clarify things a bit, it's a communal garage for an apartment building. Metal gates all around it, but nothing solid enough to keep cats out. I guess if you assumed it was a house, that would be pretty confusing.
cnk is offline   Reply With Quote
Old 12-06-2005, 01:23 PM   #7
I believe you need to attack the root of the problem. Covering the car and spraying stuff isn't the right way to go.
Go down to your local SPCA and borrow a live trap from them, and trap the cats by baiting it with sardines and putting it on your porch at night.
Don't say a word to anyone that you're doing it. Just take the cats in and be quiet about it. Should the cat have a tag, the owner will be notified and they will have to take off work and go retrieve their cat.
It will teach the cat and the owner a good lesson.
Cats are actually not supposed to be off a leash or outside one's fenced yard, just like dogs.
Old 12-07-2005, 10:56 AM   #8
cnk
Originally Posted by dbth
Check this product , I'm not a cat person , but looks like this is worth a try to spread around your parking spot.
We have dogs and use a bitter apple spray as a repellent, don't know if that would be effective with cats.
Otherwise a cover is the only alternative.
http://www.critter-repellent.com/cat/cat-repellent.php
Interesting. I'd worry that a) it might not work and b) my car would start smelling like fox urine.
cnk
