Old 03-20-2013, 02:33 PM   #21
The variability from one car to the next is amazin', eh?
Old 03-20-2013, 02:54 PM   #22
Yep
A sure sign of lack of quality control.
jotoole is offline   Reply With Quote
Old 03-20-2013, 05:34 PM   #23
Spinnaker's Avatar
2000 S
111,000 miles
3rd pump
Old 03-20-2013, 05:45 PM   #24
01 2.7L manual trans.
121K miles on original. slight bearing wear, replaced it
11K on new pump.
sb01box is offline   Reply With Quote
Old 03-20-2013, 06:04 PM   #25
recycledsixtie
recycledsixtie's Avatar
No documentation from 1st owner. No water pump done with 2nd or myself. Therefore 40k miles likely on original water pump on 2001 base Boxster.
Old 03-21-2013, 06:43 AM   #26
Very poor design....I've put two pumps on mine.
I purchased my 1999 Boxster in 2009 with 104,000 miles, and the pump went out a short time later. Then after reading Excellence Magazine, this forum and Renn Tech I changed it again after going 60,000 miles as preventive maintenance. I've got 182,000 miles on the car right now.
mnc-i is offline   Reply With Quote
Old 03-21-2013, 07:24 AM   #27
Nimbus117's Avatar
On my second, first one was replaced at 85k.
2003 Boxster 2.7L
2010 Civic Type R
Old 03-21-2013, 09:25 AM   #28
How many water pumps has your 986 been through?
What are the symptoms of a failing pump?
rondocap is offline   Reply With Quote
Old 03-21-2013, 09:44 AM   #29
2002 S 86,000 original pump
sfoster13 is offline   Reply With Quote
Old 03-21-2013, 10:14 AM   #30
Coffinhunter's Avatar
2 water pumps in 182,000 miles and you think that is a poor design?!?! I have not heard of a vehicle that went 182,000 miles without some parts needing to be replaced. I guess I should be really pissed that the timing belt needed to be replaced at 132,000 miles on my wifes car
Old 03-21-2013, 10:19 AM   #31
steved0x's Avatar
2000 Boxster S, 106,000 miles, my service records atart at 60,000 miles but there has not been a water pump replaced since. Now a whole lot of other stuff has been replaced, AOS, MAF, Ignition switch, gas and oil caps, motor mount, all the little stuff that happens. But no record of a water pump. At my next service I am doing plugs and plug tubes and I may do the pump and low temp thermostat at that time. When I take it off I'll be able to see if it is original or not and will report back.
Steve
Old 03-21-2013, 11:00 AM   #32
Replaced at 50k as preventative mainanence.
Original was still perfect.
SF-Rockster is offline   Reply With Quote
Old 03-21-2013, 03:17 PM   #33
jsceash's Avatar
None yet 52,245. I have one sitting in the garage waiting for 3.6 LN block to be returned.
Old 03-21-2013, 04:02 PM   #34
Ckrikos's Avatar
My shop is replacing mine. I had a bunch of work done then when I drove it home the water pump apparently died. my temp was running a little hotter than normal and when I parked my car it vented all of the fluid. Thing is that coolant also came out of the filler end through the cap. I'm wondering if I should change out the reservoir too. I assume that changing out the serpentine belt and pulley must have messed with the water pump causing it to fail. Btw mine was at 50k miles.
LB/GG/MB 02 2.7 sold
MB/GG 02 996TT
Old 03-21-2013, 04:39 PM   #35
Theoretical propagandist
Eric G's Avatar
Replaced the original last year at 90K and it was due.
Old 03-21-2013, 05:27 PM   #36
How much are people paying for water pump replacements? 13 years and 63,000 miles and to my knowledge,my pump is original.
litespeedp is offline   Reply With Quote
Old 03-21-2013, 06:11 PM   #37
Don't want to jinx mine so I'm not saying!
Old 03-21-2013, 06:13 PM   #38
Ok...I bought the car in July 2008 with 75K miles. Now have 107K. I've changed coolant at ~95K and coolant tank shortly thereafter.
Old 03-22-2013, 04:02 AM   #39
After 80+K miles I kept putting it off even as recently as missing an appointment to bring it just last week.
Well I guess you know what I'm goint to tell you happened jus this past Sunday night.
A strange new sound started up. I was about 15 minutes from home albeit on the highway. The sound is gettting more noticebable. To the point that I pull over and check the coolant level. Yep only half full. Oh boy. Get in and try to make to at least my Indy's repair shop another 10 minutes away...nope. Lets go five minutes later on the highway and the dash light starts blinking. Flat bed $120 (+$40 tip for the ride to my house). Then a series of unintended brainfade ensues where I forget to remove my house key from the key chain before putting the key in the shop's drop box and of course forgetting my phone in the car. No car, no phone no house keys... $160 for locksmith and $40 for the pre-paid phone I had to buy at the supermarket.
At any rate Flat6 have posted that it is in your best interest to be proactive about the watermpump and replacing it every 40K miles. The factory I belive, if not mistaken, recommend no more than 60K miles on the original water pump. Either way there's no point in waiting until it goes on the highway. I would suggest replacing it when you change the coolant tank, a known weak spot on this car that also went on my car.
Coolent light blink has nothing to do with your pump, only coolent level. I realize your pump was leaking, but if your going to drive a car with a leaky WP anyway, there's no reason to flatbed it, just add a big gulp cup full of water to the res... Make sure the gauge stays in the normal range though. Escalating temps are a reason to stop.
shadrach74 is offline   Reply With Quote
Old 03-22-2013, 06:50 AM   #40
Perfectlap's Avatar
I assumed the waterpump failed completely from the smoke that was pouring out of the side. I think it made a last death sound too. I didn't even think to check the coolant level at that point, I just called for the tow. I was even hesitant to start the engine (to drive it off the last few feet of the flatbled) until the car had been shut down for a good 45 minutes in the cold winter temps. Oddly enough until very recently I always kept a gallon of distilled water in the rear trunk...
