Old 02-21-2013, 09:51 AM   #1
IMS Guardian Question
Concerning the IMS guardian. How far apart are the two contact points? In other words, if there is never a situation where metal should be present in the oil system, it seems that the contact points should be very close together. Judging from this picture, it seems like a significant amount of metal shavings could occur prior to detection. Is the spacing such to prevent false alarms?
Also, any word on the Jr version?
thomasotten is offline   Reply With Quote
Old 02-21-2013, 10:04 AM   #2
Engine Surgeon
The spacing was purposely set through extensive development to ensure that false positives from extended oil service intervals would not occur. The IMSG Sensor is a true Magnetic CHIP Detector, not developed to be as sensitive to typical ferromagnetic "fuzz" from normal engine wear that can cause a false positive.
The IMSG Jr. uses the same exact MCD Sensor, but a different interface and is a universally applicable system that does not integrate as factory in the Porsche dash, like the IMSG Sr. does (for cars pre 2005). The IMSG Jr. is now available.
LN Engineering now sells these units and we are only the manufacturers.
Here is a sample of the type of material the IMSG MCD is designed to detect.
US Patent 8,992,089 &
US Patent 9,416,697
Old 02-21-2013, 10:18 AM   #3
recycledsixtie
recycledsixtie's Avatar
Jake - how many Boxster engines has the Guardian saved so far?
Old 02-21-2013, 12:11 PM   #4
Ims
That sounds great. From your experience is there an instantaneous type of failure that the guardian would not detect? I suppose that would be less likely.
Old 02-21-2013, 01:43 PM   #5
found
Found my answer here, post #5
http://986forum.com/forums/general-discussions/36258-ims-guardian.html
Old 02-21-2013, 01:46 PM   #6
Engine Surgeon
Yes, we had a crankshaft break in half and the unit detected the failure after the engine stopped running... Not like anything can tell you when your crank is about to shear in half, since wear metals don't exist until it grenades.
US Patent 9,416,697
Old 02-21-2013, 02:09 PM   #7
ordered
I just ordered one from the Pelican.
This seems like such a good idea.
Why wouldn't every car benefit from at least a magnetic drain plug? Or would that work against the manufacturers in court? I could imagine photos of a drain plug with metalic sludge on it being a very easy way to prove to a jury that the engine was defective prior to failure.
Old 02-21-2013, 01:43 PM   #8
Engine Surgeon
We have no idea.. With a lot of the units sold overseas and to other areas where people make no contact with us, its really hard to say.
US Patent 9,416,697
Old 02-21-2013, 03:31 PM   #9
Jake, is a motor that has shed that much metal a candidate for an IMSB replacement, or does the motor have to be torn apart and rebuilt?
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 02-21-2013, 02:38 PM   #10
Perfectlap's Avatar
Does the Guardian signal non-IMSB related metals that are potentially problematic (ie not normal engine wear)?
As in can malignant debris often be too small for detection like the benign?
just wondering if having the LN IMSB and the Guardian is overkill/redundant.
Old 02-22-2013, 04:24 PM   #11
Engine Surgeon
Absolutely, as long as the levels are high enough to be detected. Thus far the IMSG has detected failing camshafts, lifters, timing chains, rod bearings, main bearings and I am sure that it doesn't stop there. The IMSG monitors every ferro-magnetic wear component within the engine. This isn't limited to just the IMSB.
Thats a personal preference situation and will vary depending on who you ask....
That said, I know too much and have experienced these engines enough to check the entire engine for collateral damage before moving on with any resurrection after the loss of an IMSB. We are too proficient here not to take the engine apart. At this point I am fairly sure that Blake could assemble one blindfolded. Its a breeze after what we've been through, developed, experienced and applied.
Others will do everything possible to keep from disassembling the engine. They usually just waste more time and prolong the pain; the only way around the problem is straight through the middle of it.
US Patent 9,416,697
Old 02-22-2013, 04:30 PM   #12
Perfectlap's Avatar
Would any of those trip a CEL? as in before it was too late to fix anything..
Old 02-22-2013, 05:15 PM   #13
Engine Surgeon
You can leave the gas cap loose and get a CEL.... You can sling a rod through the block and never see a fault code.
Of the cars we see weekly here that are failed 2/3 of them never had a fault code or CEL before they expired. The OBDII system is more centered around emissions than anything else.
Engines don't have to gain permission before they break.
US Patent 9,416,697
Old 02-22-2013, 05:44 PM   #14
Perfectlap's Avatar
c'mon who doesn't love a surprise...
on a serious note, when you do detect those failures that you mention, how often is it cost effective to address them vs. punting for a replacement engine?
I ask because I have no idea how involved these sorts of repairs are to peform and I'm thinking of taking some preventative measures. I have no plans of ditching this car at this point.
Old 02-23-2013, 06:38 AM   #15
Engine Surgeon
Here we always address the issues. Its outside our faith to just swap in another engine, doing that is for those who lack the skills and proficiency to intervene internally.
Unlike most you'll experience we look forward to internal exploration and repair with these engines. I'd rather resurrect an engine after a failure (when it makes sense) as to create a reconstructed engine for the car, even though the latter is more lucrative.
We have fun with this stuff, which is the biggest key to being the best in the industry.
Anyway, ALWAYS carry out preventive measures. Proactive is always better than reactive.
US Patent 9,416,697
Old 02-23-2013, 07:19 AM   #16
recycledsixtie
I would like to say how happy I am with my IMS Guardian. I have had my Boxster almost 2 years and the Guardian installed about 1.5 years. It was the second major purchase after having had CV joints done. I drive it year round from +80 to -20F and don't worry about the engine. Will get the ims/clutch done a few years from now as the car only has 40k miles on it. As Jake says be proactive with servicing. Frequent oil/filter changes are a must.
Old 02-23-2013, 08:03 AM   #17
Bfan's Avatar
Same her, It was my first project after I got the car and the one I appreciate most. I am probably one of those overseas buyers but I would like to use the opportunity to thank Jake for everything.
Gunnlaugur, Reykjavik
Bfan is offline   Reply With Quote
Old 02-23-2013, 08:52 AM   #18
recycledsixtie
Bfan reminds me that a thank you is in order Jake. I would think that being in business it is easy for people to hand out crap and abuse to the bus. owners. So thanks Jake for a job well done!
Old 02-23-2013, 10:17 AM   #19
Engine Surgeon
Thanks guys. It's not like it used to be in regard to selling things. Today I only want to develop and solve problems with engines.
To be recognized is really nice sometimes.
US Patent 9,416,697
