Old 02-14-2013, 06:41 PM   #1
pjq
Inner CV joint
2004 Boxster S
I'm in the process of removing my engine. I just removed the exhaust and noticed a fine splater of grease forward of the left inner CV joint and also a small amount of grease on CV joint, is this normal? I've attached photo's.
Old 02-14-2013, 06:46 PM   #2
The clamp gets loose and grease leaks out. Grab the boot and twist it, if it moves then that's the problem. A hose clamp is the easiest solution.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 02-15-2013, 07:16 AM   #3
pjq
Thanks for the reply.
I guess with that info, should I add more grease before putting things back together? If so what is the recommended grease type?
Pat.
Old 02-15-2013, 07:50 AM   #4
Pat.
Probably a good idea to add grease but I didn't when I had some grease leakage and everything seems fine. Pelican sells the grease.
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
Old 02-15-2013, 09:05 AM   #5
1999 base
Meir's Avatar
Pat.
i used this:
Pelican Parts - Product Information: SWE-101
replacing the rubber boot during the process will be a good idea, if you are already in there.
Pelican Technical Article: Replacing Boxster CV Joints and Boots / Axle Replacement - 986 / 987
Old 02-15-2013, 10:26 AM   #6
Theoretical propagandist
Eric G's Avatar
In fact, just by four boots and replace all of them since your there.
Old 02-15-2013, 03:52 PM   #7
pjq
Ok I'll put that on the TO DO LIST for later assembly. I now have to remove the transmission and after, the engine.
I'll have to rig something to temporarily support the engine while I remove the transmission, thats going to be a PITA.
Pat.
Old 02-15-2013, 06:17 PM   #8
1999 base
Meir's Avatar
Pat.
You can get an engine bar from HF for a resneble price.
Worked great for me.
http://www.harborfreight.com/1000-lb-capacity-engine-support-bar-96524.html
Let me know if you need a 20% off cuopon.
Old 02-17-2013, 12:31 PM   #9
pjq
Thanks for the link Meir I've saved it for future needs, good prices.
I'm in New Brunswick Canada so I'm not able to get on-line purchases real quick and easy. That being said I do purchase online I just have to allow for the delivery time.
For now I'll try spanning from underneath with 2 jacks and a 4 x4 or 3X 3. This should allow me to get the transmission out and clear as well as maintain clear access to the engine with the ATV jack for the engine removal.
Pat
