Old 11-18-2005, 11:35 PM   #1
Send a message via AIM to blinkwatt
Emergency!!!!
My dad used my Boxster and came home,I went to start it and it wont do a damn thing. Wont turn the ignition on,wont pop front hood or rear without alarm pad. Any input would be greatly appreciated as I need the car in a hurry.
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
Old 11-19-2005, 12:00 AM   #2
The front hood opens how and Im charging the battery now(although it is not dead). It still wont even turn the dash lights on,or let me turn the key half way just barely. HELP!
Old 11-19-2005, 09:43 AM   #3
I guess your ignition switch may be broken, so your key stuck when it turns. Check this tread:
Ignition switch
If that is the case, that is easy and cheap to fix. Search "ignition switch" in this forum or renntech.org. I think u should be able to fine instruction about how to replace that. Hope it helps.
97Boxsterian is offline   Reply With Quote
Old 11-19-2005, 06:52 PM   #4
deliriousga's Avatar
Sounds like the ignition switch to me too. Some folks have found the switch for around $10. You can get the switch and swap it yourself or have a Porsche specialist put it in.
The dealer will want to put in the updated ignition switch which requires replacing the locking tumbler and re-programming the keys....aka $600.
1966 Wife White/Brown Top
Old 11-19-2005, 07:36 PM   #5
I think, based on replies on PPBB that the steering wheel had tension on it pushing it up against the lock. All he needed to do was move the wheel while he was trying to turn the ignition key.
The comment was something like, "I never lock my steering wheel but my dad did". Seems someone doesn't know how steering locks have worked for the last 20 years.........
It would be fun watching him try to start a 60's era Ford pickup (is there anyone else here that remembers the cross handed technique needed to get the steering lock to release?)
mjw930 is offline   Reply With Quote
Old 11-19-2005, 07:45 PM   #6
No, but one time I tried to drive an old Ford 50, or 100 (or some pathetic number). I thought it was an "automatic" but it was really a "three on the tree." You could imagine my confusion...
1997 Honda Accord | V6
2004 BMW 330i | ZHP | SOLD
2000 Porsche Boxster | SOLD | http://www.986forum.com/forums/showthread.php?t=9114
http://www.kryzak.com/storage/986sig12.jpg
http://kryzak.tumblr.com
Jeph is offline   Reply With Quote
Old 11-19-2005, 07:55 PM   #7
Actually, the more I remember it wasn't the steering lock you had to disengage, it was the park lockout you had to engage to get the starter to energize. Ah, those were the days
