Old 12-29-2012, 02:35 PM   #1
Jager's Avatar
Jack Stands
Check these out:
JackPoint JackStands Work Better
Jäger
300K Mile Club
Old 12-29-2012, 03:02 PM   #2
husker boxster's Avatar
Simple, innovative, cool....
but a bit spendy at 3 bills.
1989 928 S4 5 spd - black
Old 12-29-2012, 03:14 PM   #3
Newb
V-Rod's Avatar
Clever! And I do like the fact that they can be stacked when stored. And that $300 is for a pair.
1999 Boxster Ocean Blue Metallic/Savannah Beige
2001 Harley Davidson Road King w/Ultra Kit Black/Chrome
2004 Jaguar XJ8 Seafrost Metallic Green/Sand
2008 Land Rover LR3 Alaska White/Alpaca
2012 Honda Odyssey Touring Dk Grey/Lt Grey
V-Rod is offline   Reply With Quote
Old 12-29-2012, 03:22 PM   #4
doragman's Avatar
very innovative
'99 986 Baton Rouge, LA
doragman is offline   Reply With Quote
Old 12-29-2012, 03:42 PM   #5
schnellman's Avatar
I really like these, but there's no way I'm going to spend $300 for new jack stands.
Old 12-29-2012, 03:55 PM   #6
Yeah, sort of cool, but...
The downside? Non-height adjustable!
Old 12-29-2012, 04:06 PM   #7
Would probably only need 1 pair. Jack the car up from the rear post and the front goes up along with it. Stick a pair of regular stands in the front.
Old 12-29-2012, 04:10 PM   #8
My car is lowered (PSS9's). No way that I'd ever be able to get the jack and the jackpoint jack pad under the car. I had to remove the flat jackpad entirely from my race jack and it still barely fits.
Old 12-29-2012, 05:10 PM   #9
Gforrest2's Avatar
+1 And wait a little bit. H-F will have a knock-off for less than $100 before you know it.
Glen
Gforrest2 is offline   Reply With Quote
Old 12-30-2012, 05:13 AM   #10
Pro's: What a great idea; would like to have.
Con's: Too expensive; non-height adjustable; no lift weight specs; what material is it made of.
To THSTONE: if you place a 2x4 in back of your rear tires (or in front of your front tires) and drive up on it, this may give you enough room to use your jack.
Soetekouw is offline   Reply With Quote
Old 12-30-2012, 06:18 AM   #11
Carnut
AndyA6's Avatar
Not impressed. Bulky.
'14 Boxster
Old 12-30-2012, 06:47 AM   #12
thom4782's Avatar
Innovative idea. While I don't plan to buy, here are a few more technical details from the vendor's site.
"We use Almag 535, a light weight, high performance, high strength Magnesium Aluminum alloy and wall thicknesses of 1/2 inch or more to evenly distribute load throughout the jack stand base. The results are jack stands that meets ANSI standards at 4000 pounds and a stable base nearly twice as wide as conventional jack stands."
Old 07-02-2013, 08:45 AM   #13
Vista glass
Vista glass's Avatar
Rare Porsche jack stands
Well it has been raining everyday. It probably will until September. Time for shop work. After research, I picked up a set of 6 ton jacks for routine activities. I found a set with ratchets and pins at Northern Tool on sale for $40.00 per set.
Not one to leave well enough alone I modified them by installing rubber pads onto the bearing surfaces. I have 1/4 inch thick material cut to fit and affixed with the E6000 adhesive. E6000 is pretty good stuff weather resistant and I have not had a failure with it so far.
Since I am usually alone in my man cave I used bright colors to indicate post positions for easy reference to level the vehicle. I got the six tons so I can use them for other toys and tools in the stable
Of course we can not have rusty stands under the Boxster and it does stay damp down here. I used the Duplicolor Clear Wheel paint to seal every thing up.I have had very good service from this product on wheels, calipers and anything else I have used it on so long as the prep was done right.
So they are not "really" Porsche jack stands but I think the caliper decals do add a certain savoir fare to these imports
I sure hope it quits raining soon !
Vista glass is offline   Reply With Quote
Old 07-02-2013, 09:17 AM   #14
Forum Contributor
Those are cool, I'd buy dentless door repair first but that's me. Also, unibody is not a new concept, my 71 Fiat is built the same way. Also, if done carefully with some underside mouse pad on the jack, using standard gear is just fine.
ghostrider300 is offline   Reply With Quote
Old 07-02-2013, 10:25 AM   #15
Johnny Danger's Avatar
Ron Popeil has nothing on these people !
