Old 10-30-2005, 07:27 PM   #1
deliriousga's Avatar
Originally Posted by 97Boxsterian
Thank you all for the known problem of the fog light. After I slowly knock the bulb holder with my screw driver, the break light work. It is a touching problem. te light holder is getting old, hope it won't loose out again.
Two ways to help with the bulb contact:
First, see if the flexible part that contacts the bulb is flattened. If so, use a jeweler's screwdriver to push it out a little, but be careful not to break it off.
If the flexible part is very loose, or flattens back easiely, you can put some solder behind it to keep it from pushing back.
1966 Wife White/Brown Top
Old 10-30-2005, 08:56 PM   #2
Thank you John once again! I will try that if it loose again.
97Boxsterian is offline   Reply With Quote
