Old 10-26-2012, 04:44 PM   #3
SPB racer
Minor addition to 73s assessment below would be that - you didn't say whether you were using stock or Adjustable drop links. If your drop links are adjustable you do not want to load one way or the other on the rollbar - in fact, for most circumstances you want to evenly unload the bar. Have both wheels evenly off the deck (in full droop) and you should be fine no matter what you use.
You should not be messing with your alignment either front or back simply by replacing drop links.
Jittsl is offline   Reply With Quote
