Old 10-23-2012, 05:44 PM   #1
sweeper's Avatar
Sun visor sticker removal- simplified
So I bought the "vinyl cover up/cut outs" to make my sun visors look.....better.
Great quality and it was a great transaction on Ebay....I certainly hate to take business away from this guy but there is an easier way.
While in the process of getting ready to slather some silicon on my car to make these stick- I used some wax/de-greaser to clean the surface- it is for automotive plastic-(among other surfaces) the label wiped off in less than a minute.
I've read the other posts about using denatured alcohol with some heavy scrubbing. It took me 5 minutes to do both visors (both labels on each)
1. Grab several paper towels to wrap around sun visor- This will protect the seats from over-spray and remnants of the sticker.
2. Spray the sticker- Just a few quick shots to cover the sticker. Let it sit for about a minute- ADVANCE AUTO ($8.95)
3. Wipe the sticker off.
4. I used 409 to clean and then wiped it down with Armor-all
For the "AIR BAG" decal on the other side- I sprayed a little on a cotton cloth and a little on the decal and wiped it a few times and it wiped off just as easy.
sweeper is offline   Reply With Quote
Old 10-23-2012, 06:01 PM   #2
Theoretical propagandist
Eric G's Avatar
Nice job! I just took my cover off and stored them but I like you approach!
Old 10-23-2012, 08:24 PM   #3
jaykay's Avatar
Great! no ill effects???
I was just looking at my ugly stickers and dreading the work
986 00S
Old 10-24-2012, 12:43 AM   #4
sweeper's Avatar
No ill effects that I can see. I'm guessing that leaving the spray on overnight may not be a good idea.
The can says it contains hydrochloric acid? Just kidding...looks like it is alcohol based.
1997 Boxster- 28k, de-snorked, de-baffled, RSS UD, Dansk "hotdog" sport exhaust.
1985 BMW 635CSI- 30k, 5-speed, LSD
Old 10-24-2012, 05:46 AM   #5
keysguy's Avatar
I'd be a bit worried that that would make the plastic brittle. I used a removal product and it worked great but after a month the plastic just broke apart. I ended up searching e-bay for European visors. They don't have the warning and for under $100 US I got a pair shipped to me.
1979 911 Targa SOLD!!!!
1985.5 944 SOLD!!!!
2000 Boxster
keysguy is offline   Reply With Quote
Old 10-24-2012, 05:49 AM   #6
2001 Arctic Silver 2.7
tony_fury's Avatar
I used isopropol alcohol on a microfiber towel.. same results..
after removal I used armor-all..
RMS, IMS, 87.5K
Old 10-24-2012, 10:30 AM   #7
Autobahn Glanz
WhipE350's Avatar
I'm sure I'll get slammed but I used paint thinner. Came of instantly and did zero damage. I then dyed it with the same dye I used on the seats after I restored them. My visors look like new.
Old 10-24-2012, 12:31 PM   #8
1999 base
Meir's Avatar
which dye did you use on your seats ?
Old 10-24-2012, 02:40 PM   #9
Autobahn Glanz
WhipE350's Avatar
I used Home Page | Leatherique Restoration Products but you could use any water based dye. Dilute it a little and blend with the rest of the visor.
Old 11-07-2014, 02:42 AM   #10
Please clarify by paint thinner you mean mineral spirits ?
rfuerst911sc is offline   Reply With Quote
Old 11-07-2014, 06:17 AM   #11
I am my own mechanic....
Timco's Avatar
Let me save yall some time.
Paint thinner did nothing.
Oven cleaner took it off layer by layer. Messy.
Lacquer thinner takes it off in real time. Rotate rag frequently. Just dab some on the rag tip. No effect to visor that I can see.
'08 VW Touareg T-3 wife's car
Old 11-07-2014, 12:06 PM   #12
Autobahn Glanz
WhipE350's Avatar
Let me clarify, I looked at the can, it was Paint and Varnish Remover in gel form. Very strong. Probably stronger than nail polish remover.
It did zero damage to the visor other than a little fading. Using a nice water based dye they actually looked new. I showed them to many other folks at car shows who had done their own with other methods and it was night and day. They didn't actually believe me.
If you are near Charlotte come by, I have 16oz of dye left.
Old 10-25-2012, 08:30 AM   #13
Skrapmot's Avatar
Originally Posted by vath2001 View Post
Simple: Bought news one from Suncoast for $20 each. But then both of mine were broken.
Ditto: a bit less work and my hinges were getting floppy.
Old 11-03-2014, 09:33 AM   #14
Timco's Avatar
Bump after a quick search....great idea.
Old 11-06-2014, 01:33 PM   #15
Drives with Scissors
TMass's Avatar
Wow; that stuff worked well and is strong.....sticker came right off. I timed it one minute exactly.It took a little of the finish off on the cover and where I had not covered the visor. I used some premier Liquid black shoe polish to put a finish back on the places that had been dulled. It's actually shinier than ever after running the shine sponge across it.
2002 Boxster S Arctic Silver
TMass is offline   Reply With Quote
Old 11-07-2014, 02:04 AM   #16
Bruce Wayne's Avatar
do you take the tags off mattresses too ?
986 x2 6sp
2x Range Rover Vogue 4.6
2004 MX5 Sport 6speed Strato Blue (wifelet)
2x Range Rover Classic & CSK
Bruce Wayne is offline   Reply With Quote
Old 11-07-2014, 06:35 AM   #17
Nine8Six's Avatar
Where the acetone gone? Safe on any composites...
No need for home depot... just locate wife's manicure kit. Don't get caught
Old 11-08-2014, 08:46 AM   #18
Timco's Avatar
Fyi, the lacquer thinner works just as well on the decal on the bottom of the visor. Pics later but they are all gone and visor is 100%.
Old 11-11-2014, 06:06 PM   #19
Acetone removes those labels very easily. Much better having those warning billboards removed.
Old 08-01-2019, 09:50 AM   #20
Visor warning label residue optional solution.
I purchased a '98 986 in May and found the back side of the visors to have the airbag warning labels cracking and peeling. The stickers came off in pieces, leaving an adhesive residue. I tried using isopropyl alcohol, Goo Gone, Magic Eraser, etc. but the residue seemed embedded in the textured vinyl. A friend and Porsche enthusiast had told me about a leather refinisher (found it on Amazon along with a pre-treatment cleaner) for a slightly warn area on the edge of the driver's seat. The leather boot on the manual shift also had areas of wear. The refinisher worked awesome here, so I thought why not try it on the visors. I used a blue shop paper towel to add a "textured" look to the visor, this step is probably not necessary however. It just ended up removing some of the refinisher, requiring a second coat. Hope this helps someone. Good luck!
ZzzTime is offline   Reply With Quote
