Old 10-21-2012, 02:10 PM   #1
Foam coming through my air vents!?!?!
I have small pieces of black foam blowing through my air vents, Any idea where it's all coming from or how I can clear it all out. Little bits of black foam flying at me when driving is becoming a huge pain in the ass!!
Help!!
Dgrange is offline   Reply With Quote
Old 10-21-2012, 03:10 PM   #2
This is likely the foam gasket material used in the HVAC system to seal the various "flap" type doors that open and close to divert blower air from your feet to your dash vents to your defrost vents. Not much you can do short of opening up the system. The good news is that at some point it will stop... the bad news is that the doors in your HVAC system will no longer have gaskets to seal against.
There are a couple of other place it may be coming from. I would pull the filter and housing and see how it looks. The filter housing is under the bonnet on the pax side.
Pelican Technical Article: Boxster Air Filter / Pollen Filter Replacement - 986 / 987
shadrach74 is offline   Reply With Quote
Old 10-21-2012, 03:15 PM   #3
Great, thanks for the info.....sounds like a night in my garage tomorrow night!
Thanks again.
Old 10-21-2012, 03:28 PM   #4
Many of us complain about this. A typical problem with older boxsters. I thought mine would run out of foam bits spitting at me and collecting on the floorboards, but it's been doing it steadily for two years now.
I guess I need to tear off the dash screw by screw, find the rest of it, remove it, and replace it all.
Sounds like a good time to send the dashboard off for leather to be added to it, huh!
Old 10-21-2012, 03:51 PM   #5
Thanks - I may be able to give you a run for your money on putting $$$$$ into these cars, I have had mine for 14 days and by Friday will have spent over 4k!!!!
Unbelievable! But still live it.....
Old 10-21-2012, 03:55 PM   #6
This is a story that I'm sure we'd all love to lean more about!
Old 10-21-2012, 06:06 PM   #7
1999 base
Meir's Avatar
The full solution:
A/C evaporator replacement-A/C foam flakes
Old 06-13-2013, 04:24 AM   #8
tanque55's Avatar
The foam coming from your AC vents is a common problem on older cars. As the rubber and foam gets older it starts breaking down, specially in warm climates. Without tearing the dash apart not much to do about it.
tanque55 is offline   Reply With Quote
Old 06-13-2013, 06:22 AM   #9
thom4782's Avatar
Keep searching the forums. There is a procedure to R&R the foam without removing the dash and opening up the air handling box for the heat and AC. The fix involves removing the heater core, but I don't remember off the top where to find the post.
Found it: http://www.renntech.org/forums/tutorials/article/121-fixed-my-lack-of-heat-problem-here-is-the-procedure/
