Old 09-12-2012, 11:39 AM   #1
VFX
If the box was out the engine would still start & not kill the valves & plugs right?
Spoke to the shop again & they're admitting that they diagnosed it incorrectly & have now run other tests on it.
Compression very low & timing is out.
Could be a broken balancing shaft?
Any ideas?
Sounds like I'm racking up a bill large enough to have bought & installed a 3.2L already!
VFX is offline   Reply With Quote
Old 09-17-2012, 02:25 PM   #2
The Radium King's Avatar
well, lemonade out of lemons. as a 2005, your car should be able to take any 997 or 987/cayman engine up to 2009, so look at it as an opportunity to get a 3.4, 3.6 or even 3.8 in there for less than the cost to rebuild your current engine (if it needs rebuilding).
once you've disentangled yourself from the current shop, perhaps let us know who it was so as to facilitate some caveat emptor.
Old 09-17-2012, 06:27 PM   #3
well, lemonade out of lemons. as a 2005, your car should be able to take any 997 or 987/cayman engine up to 2008, so look at it as an opportunity to get a 3.4, 3.6 or even 3.8 in there for less than the cost to rebuild your current engine (if it needs rebuilding).
+ 1
"as a 2005, your car should be able to take any 997 or 987/cayman engine up to 2008"
Old 09-12-2012, 01:04 PM   #4
VFX
Jcb I'm wondering the same thing.
They're very well respected & been around for a long time so I kinda trusted them.
Old 09-12-2012, 01:09 PM   #5
timing issues are a very bad thing in a boxster. where in canada are you, as you need a shop that can save your engine at this point. certainly do not run it again.
Old 09-12-2012, 01:17 PM   #6
VFX
In Vancouver.
Old 09-12-2012, 01:33 PM   #7
lemme guess - is your car at jacobs?
mcl and weissach are good dealer mechanics. jeff at pacific western performance and james at scan automotive are both good guys that know the m96 engine (james races a 3.6 boxster and jeff tracks a cayman).
Old 09-12-2012, 01:38 PM   #8
Sounds like the IMS might have let loose, hope it's something else. I'd try and get the car to someone who specializes in the M96.
Uller God is offline   Reply With Quote
Old 09-12-2012, 02:15 PM   #9
VFX
Not naming names as I want a decent resolution to this.
Would an IMS failure cause some obvious piston/valve interfacing?
Wouldn't an IMS failure be more obvious?
I'm not a tech so I've really no idea.
Old 09-12-2012, 02:33 PM   #10
i'm no expert but, from what i've read, timing chains can jump teeth if given the opportunity by wobbly ims bearings, failed chain ramps, worn tensioners, etc.
Old 09-12-2012, 03:15 PM   #11
If you have had a failed IMS with piston/valve contact, both your oil and oil filter should be full of metal. Drain the oil and look at it; pull the filter and cut it open. If the IMS went, it will be obvious.
Old 09-12-2012, 03:24 PM   #12
VFX
They allegedly performed a maintenance service on it (usual suspects oil, filters etc.) whilst waiting for fuel pump to arrive.
So I guess they would've caught that immediately.
Old 09-12-2012, 03:39 PM   #13
tonycarreon's Avatar
if you have access to another car, drive to the shop and have them show you everything they're talking about. don't say you don't understand, don't say you're a neophyte. write it all down, then go home and search for it. learn what they're trying to sell you.
to me, a shop that can't tell the difference between a bad fuel pump and a catasrophic engine failure is not reputible.
Old 09-12-2012, 04:08 PM   #14
My pump went out in the garage when trying to back out. 2 days and $216.95 later The car started and ran perfect. Looking at the old pump I see a plastic impellere semi/glued to a small shaft of a 12 volt dc motor. This failure is due to the "start" of the spin after years of weakness brought on by chemical deterioration/reaction/attack on plastic. At 90 K it was expected. Just like any of my service trucks. "It's a fuel pump" Hope you are back on the road soon !!!
milliemax is offline   Reply With Quote
Old 09-12-2012, 04:06 PM   #15
VFX
Time for any Vancouverites to help out with a list of recommended m96 specialists.
Old 09-12-2012, 05:15 PM   #16
VFX
We know it's not the fuel pump.
It's a major catastrophic engine failure that the 'specialist' somehow missed for the 1st two days.
Old 09-12-2012, 05:20 PM   #17
Steve Tinker's Avatar
987's have the strainer/ filter combined as part of the fuel pump assembly.
The earlier 986's have a seperate fuel filter just forward of the engine
2001 MV Agusta F4.
Old 09-13-2012, 08:35 AM   #18
VFX
Ok so my options as presented to me by the shop.
New engine from Porsche at $20k plus fitting.
Used engine but they can't find one.
Spend 15 hrs extracting engine & splitting the case, diagnose & fix the issues, spend 15 hrs refitting everything.
Option 3 will cost 30 hrs labour at $125/hr plus taxes & plus whatever it costs to remedy to fault.
Damn!
Old 09-13-2012, 08:45 AM   #19
BYprodriver's Avatar
Damn!
You need to get to the shop & see the evidence of this in the oil filter! The shop should show you this. Before you go call on the phone & tell them you can't afford to fix it & what you owe them so far for the bad diagnosis. Have the car towed to 1 of the other shops mentioned earlier!
Old 09-13-2012, 08:50 AM   #20
VFX
It's already at one of the shops previously mentioned.
