Old 09-12-2012, 03:15 PM   #11
JFP in PA
If you have had a failed IMS with piston/valve contact, both your oil and oil filter should be full of metal. Drain the oil and look at it; pull the filter and cut it open. If the IMS went, it will be obvious.
