Old 08-28-2012, 05:05 AM   #1
tire question
I blew out a rear tire (ran over a screw, tire lost air on the highway and it tore up). No damage to the car otherwise.
The remaining three tires are pretty new (within 5K-7K miles), so I will keep the remaining tires and just buy a replacement.
Now my questions:
- Should I rotate the other rear?
- Replace the side that flatted and leave the other rear alone?
- On a 986S, does one side of the car get more wear in the rear due to the power train?
Thanks.
SOLD - 2002 Boxster S - PSM, Litronics, De-ambered, Bird Bike Rack, Hardtop, RMS leak...
fatmike is offline   Reply With Quote
Old 08-28-2012, 05:11 AM   #2
DIY extremist
black_box's Avatar
1 - If you have asymmetric tires, then no.
2 - Probably, depends on wear
3 - my right rear tends to eat up wheel bearings, but both sides eat up tires.
"Betty" -- 2000 Boxster S, Triple Black, loaded except PSM (sold to a good home)
"Veronica" -- 2008 Boxster S, Arctic Silver on Blue
"Maleficent" -- 2007 Cayman S, Red and Black, TPC Turbo 3.6L 460 RWHP, H&R RSS Coilover / TPC stage 2 suspension
black_box is offline   Reply With Quote
Old 08-28-2012, 11:07 AM   #3
1. There is no particular reason to rotate the other rear.
2. Yes, just replace the damaged tire.
3. No, both sides should generally wear evenly. If they are not (to a significant degree), then something is likely wrong.
