Old 08-05-2012, 01:58 PM   #1
what's this?
What's the pipe running underneath the car on the right hand side between the 2 blue lift clamps? Has it got to do with the ac system ? It's cracked on mine and ac is not cooling.
rene525d is offline   Reply With Quote
Old 08-05-2012, 02:40 PM   #2
tonycarreon's Avatar
AC low pressure return line. a lot of them get crimped (usually when an unknowing shop tries to lift the car and doesn't use the proper jack points), but as long as it's not totally pinched it should still cool. if it's cracked, that's probably your issue with the AC.
i was quoted $765 in '09 at the stealership to replace/repair.
Old 08-06-2012, 12:07 AM   #3
Yes its cracked, in fact that area looks to be damp and it tests positive for the A/C dye using UV light. Any idea if the cracked part can be cut off and a new one welded?
Old 08-06-2012, 02:23 AM   #4
Seems quite common these days.
The pipe can be cut and a straight crimped in, but you need an AC engineer with the tools.
The whole pipe is about £100... but its not a nice job to replace the pipe as it joins at the rear wheel and then up at the windscreen scuttle, so you need to empty out the wheel well and feed the pipe up there.
David
BestGear is offline   Reply With Quote
Old 08-06-2012, 03:09 AM   #5
I will go to my mechanic, he is also an AC engineer and have him sort it out. Pity that I'm missing using my AC unit in this heat.
Old 08-06-2012, 07:11 AM   #6
I decided to replace the whole thing to be on the safe side. Do you guys happen to have the part #?
Old 08-06-2012, 07:53 AM   #7
Bruce Wayne's Avatar
here you go..
Porsche 986 (and all Porsche) Parts Diagram access links
986 x2 6sp
2x Range Rover Vogue 4.6
2004 MX5 Sport 6speed Strato Blue (wifelet)
2x Range Rover Classic & CSK
Bruce Wayne is offline   Reply With Quote
Old 09-13-2012, 02:40 PM   #8
Hey guys,
I still am not able to figure out with part # that is from the parts catalogue. Anyone can help?
Old 09-13-2012, 05:00 PM   #9
1999 base
Meir's Avatar
Hey guys,
Look at that diagram.
Porsche Boxster Refrigerant Circuit Parts
You need part 10 or 6. Make sure to look at the remark column to select to correct part number for you year model.
Old 09-16-2012, 11:17 PM   #10
Thanks Meir! That's just what I needed.
