Originally Posted by rene525d
. Any idea if the cracked part can be cut off and a new one welded?
Seems quite common these days.
The pipe can be cut and a straight crimped in, but you need an AC engineer with the tools.
The whole pipe is about £100... but its not a nice job to replace the pipe as it joins at the rear wheel and then up at the windscreen scuttle, so you need to empty out the wheel well and feed the pipe up there.
David
