		|  08-01-2012, 07:00 AM | #1 |
	| Registered User
				Boxster S Alarm keeps on going off!!!
			Hey guys,
I really need to find a solution to my 01 boxster S alarm which is going off regularly    I got complaints from neighbors and cops even came to my girl's house late @ night, any suggestions?
		|  08-01-2012, 09:10 AM | #2 |
	| Registered User
			Easiest thing to do is scan the car with a PIWIS or Durametric system, it will have the last ten alarm trips in memory so you can see what is causing it............
				__________________“Anything really new is invented only in one’s youth.  Later, one becomes more experienced, more famous – and more stupid.”  - Albert Einstein
		|  08-01-2012, 09:29 AM | #3 |
	| Registered User
			Open the battery cover, and disconnect the wire to the alarm horn. It is a separate horn from the one in the steering wheel.  5 minute job.  Don't think you even need any tools (but a screwdriver might help disconnect the cable, it has one of those locking end clips IIRC.
 I've done this because alarms in the city are completely useless, and just annoy the neighbors.
				__________________Some kind of happiness is measured out in miles
 2003 Midnight Blue S
 LN IMS Retrofit
		|  08-01-2012, 10:29 AM | #4 |
	| Registered User
					Originally Posted by CrazyBoy  Hey guys,
I really need to find a solution to my 01 boxster S alarm which is going off regularly    I got complaints from neighbors and cops even came to my girl's house late @ night, any suggestions? |
Tell your neighbors to stop messing with your Boxster at night
I have had my Boxster for about 8 years now and have never heard my alarm go off, even with me trying the motion sensor and such to try and trigger it.    |
		|  08-01-2012, 11:39 AM | #5 |
	| Certified Boxster Addict
					Originally Posted by 2003S  Open the battery cover, and disconnect the wire to the alarm horn. It is a separate horn from the one in the steering wheel.  5 minute job.  Don't think you even need any tools (but a screwdriver might help disconnect the cable, it has one of those locking end clips IIRC.
Thank you, thank you. My alarm beeps every time that I lock the car because something isn't closed properly. Of course, everything IS closed, there is just a switch somewhere that isn't registering with the alarm module correctly and its not worth the time for me to hunt it down.
				__________________1999 996 C2 - sold - bought back - sold for more
		|  08-01-2012, 01:33 PM | #6 |
	| Opposed to Subie Burble
			Check to be sure your ceneter console lid is indeed closed.  It may look it and not actually be secure.
 Also, do you still have your stock radio?  If you've changed that out to an after market head unit, there's a grounding strip on the back of the stock unit that grounds out to a wire in the console.  If you lose that contact, the car thinks the radio has been removed by thieves/vandals/rapscallions and wil sound the alarm.  If you have replaced the radio with an aftermarket, you'll want to resolve that issue.  If you haven't, check it anyways, as the contact or wire may have built up some corrosion and lost the ocntact.
				__________________-O/D
 IMSR + RMS
 Robbins glass window top
		|  08-01-2012, 01:37 PM | #7 |
	| Registered User
			Battery is a few months old, only thing is I got a 2DIN Pioneer radio which I gotinstalled by a professional, I read somewhere else that the original radio is part of the alarm system and this is why the alarm goes off due to the missing component. I get 1 beep every time I lock the doors.
		|  08-01-2012, 01:39 PM | #8 |
	| Registered User
			I believe this is the problem and the professional @ future shop that installed it didnt
notice this...
					Originally Posted by Overdrive  Check to be sure your ceneter console lid is indeed closed.  It may look it and not actually be secure.
		|  08-01-2012, 01:45 PM | #9 |
			Happens a lot more frequently than you might think.  It's not a very well known feature of the car unless you or someone you know has experienced this phenomenon after a new head unit install.
 Hope you're able to sort that out soon.
 IMSR + RMS
		|  08-01-2012, 02:32 PM | #10 |
	| Registered User
					Originally Posted by Overdrive  Happens a lot more frequently than you might think.  It's not a very well known feature of the car unless you or someone you know has experienced this phenomenon after a new head unit install.
On my 2001 S the radio removal security tab is in the lower slot on the left hand side below the AC Vent (Upper console).
It plugs into a small metal tab that rubs against the radio case thereby grounding it.
				"It broke because it wants to be Upgraded   "
Short Shifter, Touch Screen Dual Din Radio, 03 4 Bow glass Top  (DD & Auto-X since May 17,2012)
		|  08-02-2012, 06:46 AM | #11 |
			Nice!  How convenient that we come across this issue right around the time Ray's doing his 2DIN install.
 I imagine the design changed little, if at all, over the years and between the different CDRs used in Boxsters, so that picture should help you figure out what's up with your car.
 IMSR + RMS
		|  08-02-2012, 07:36 AM | #12 |
	| 2001 Arctic Silver 2.7
					Originally Posted by CrazyBoy  Battery is a few months old, only thing is I got a 2DIN Pioneer radio which I gotinstalled by a professional, I read somewhere else that the original radio is part of the alarm system and this is why the alarm goes off due to the missing component. I get 1 beep every time I lock the doors.
With that NOT grounded properly you will get 1 beep every time you lock the doors.
I verified this when installing my new radio as well.
Good pic Ray..
It was designed that if the radio is removed it disconnects the ground contact invoking the alarm.
T
				__________________2001 Boxster - Arctic Silver Metallic
 RMS, IMS, 87.5K
		|  08-02-2012, 09:31 AM | #13 |
	| Registered User
Reminds me of an article I read many years ago, a car thief caught “told all” to reduce his time in prison. There was a Corvette he wanted desperately.  For many nights in a row he would go bump the car to set-off the alarm and then run and hide in the bushes. He did this for a couple weeks until one night the alarm did not go off… Bye-Bye Corvette!
				__________________Jäger
 300K Mile Club
		|  08-02-2012, 09:54 AM | #14 |
	| Registered User
		| Reminds me of an article I read many years ago, a car thief caught “told all” to reduce his time in prison. There was a Corvette he wanted desperately. For many nights in a row he would go bump the car to set-off the alarm and then run and hide in the bushes. He did this for a couple weeks until one night the alarm did not go off… Bye-Bye Corvette! |
yep that's a common ploy.. another one from a reformed professional car thief who stole to order for the export market was that he would wear a suit and carry a brief case, he could steal a car in broad daylight in a crowd..
who would question a businessman  in suit, with a briefcase open on the roof 'effing and blinding at 'his' car trying to shut the alarm off.
				__________________986 x2 6sp
 2x Range Rover Vogue 4.6
 2004 MX5 Sport 6speed Strato Blue (wifelet)
 2x Range Rover Classic & CSK
		|  08-02-2012, 10:00 AM | #15 |
	| Registered User
					Originally Posted by tony_fury  With that NOT grounded properly you will get 1 beep every time you lock the doors.I verified this when installing my new radio as well.
 T
 I have a aftermarket radio as well no wonder the alarm chirps everytime I arm it.
				__________________2K Boxster White/Grey Int./Hardtop/TIP   |
		|  08-03-2012, 04:12 PM | #16 |
			I have the stock radio so that's not the problem. Hence, I removed the wire to the alarm horn this afternoon. More like a 3 min job, no tools required. Just open the front trunk, remove the drivers side cowl cover, press the top and bottom retaining springs on the connector together and wiggle the connector off. Cover both sides of the connection with electical tape, then zip tie the cable/connector to the bracket so its not flopping around. Replace cover, close trunk. Done. And now, no more beeping when I lock the car!
Here is the location:
		|  08-06-2012, 09:41 AM | #17 |
					Originally Posted by thstone  I have the stock radio so that's not the problem. Hence, I removed the wire to the alarm horn this afternoon. More like a 3 min job, no tools required. Just open the front trunk, remove the drivers side cowl cover, press the top and bottom retaining springs on the connector together and wiggle the connector off. Cover both sides of the connection with electical tape, then zip tie the cable/connector to the bracket so its not flopping around. Replace cover, close trunk. Done. And now, no more beeping when I lock the car!   |
Also no more beeping if anyone ever breaks into your car...
 IMSR + RMS
		|  07-17-2013, 06:15 PM | #18 |
	| Registered User
			Best solution yet.  Just disconnect the alarm horn.  Thank you 2003S.  There's nothing more embarrassing than having the neighbors in my condo unit call me up in the middle of the night complaining about the alarm.  Really appreciate that tip.
		|  09-19-2016, 08:14 AM | #19 |
	| Registered User
			I've tried all the above fixes and it worked for about 2days... no random horn beeping... then today it just went off in my garage... Grrrr.... frustrating to all get up. And the ask the dealer why this would happen. They want $250 just to diagnose it..
	|  Posting Rules |
		You may not post new threads You may not post replies You may not post attachments You may not edit your posts
 |  |  |  All times are GMT -8. The time now is 05:26 AM.
